CJ stock front springs - JeepForum.com
post #1 of 4 Old 09-22-2013, 07:46 PM Thread Starter
auburnhunter
I have a '72 CJ6 that I am doing a light restoration on. I am considering lifting it 1.5 inches. It needs new shackles anyway so that would be the easiest, and 1.5" lift is as much as I want to go with shackles, anything more needs to be spring lift. The problem is I cannot really tell how worn my springs are.
I am in the army and the Jeep is in another state so I am not sure how many leafs I have. It is a 6 cylinder though. Can someone get a pick of the front springs, from the side, so I can compare mine? Without the tire and the axle on a jack would be even better. Thanks.
"The problem with quotes on the internet is that you never know if they are real or not" - Abraham Lincoln
auburnhunter is offline
post #2 of 4 Old 09-22-2013, 08:17 PM
WSS
WSS's Avatar
1972 CJ5
To get an inch and a half lift using shackles, you would have to have shackles three inches longer than you have now, that would make a mess of your steering. Might be better to get the right springs and leave the shackles stock. A spring lift leaves most of the integrity of the steeing in place. You might need a taper shim to get your angle back but thats about it.
Thanks for serving brother!
Here is a pic of my stock width but 2.5" lift springs:
WSS is online now
post #3 of 4 Old 09-22-2013, 10:01 PM Thread Starter
auburnhunter
I can tell by looking at yours that mine are just too flat and worn out. Guess I will have to get some new ones. What brand springs did you go with and how is the ride?
post #4 of 4 Old 09-22-2013, 11:03 PM
WSS
WSS's Avatar
1972 CJ5
The ride is great. The PO put on the springs right before I bought the Jeep from him. I do not remember the name, it was on a paper sticker stuck to the springs until I pressure washed it off.
WSS is online now
