-   Jeep Picture Requests (http://www.jeepforum.com/forum/f59/)
-   -   CJ stock front springs (http://www.jeepforum.com/forum/f59/cj-stock-front-springs-1613313/)
auburnhunter 09-22-2013 07:46 PM
I have a '72 CJ6 that I am doing a light restoration on. I am considering lifting it 1.5 inches. It needs new shackles anyway so that would be the easiest, and 1.5" lift is as much as I want to go with shackles, anything more needs to be spring lift. The problem is I cannot really tell how worn my springs are.
I am in the army and the Jeep is in another state so I am not sure how many leafs I have. It is a 6 cylinder though. Can someone get a pick of the front springs, from the side, so I can compare mine? Without the tire and the axle on a jack would be even better. Thanks.
WSS 09-22-2013 08:17 PM
To get an inch and a half lift using shackles, you would have to have shackles three inches longer than you have now, that would make a mess of your steering. Might be better to get the right springs and leave the shackles stock. A spring lift leaves most of the integrity of the steeing in place. You might need a taper shim to get your angle back but thats about it.
Thanks for serving brother!
Here is a pic of my stock width but 2.5" lift springs:
http://i1344.photobucket.com/albums/...s3513a08b.jpeg
http://i1344.photobucket.com/albums/...s09f4e769.jpeg
http://i1344.photobucket.com/albums/...pscd619d6d.jpg
auburnhunter 09-22-2013 10:01 PM
I can tell by looking at yours that mine are just too flat and worn out. Guess I will have to get some new ones. What brand springs did you go with and how is the ride?
WSS 09-22-2013 11:03 PM
The ride is great. The PO put on the springs right before I bought the Jeep from him. I do not remember the name, it was on a paper sticker stuck to the springs until I pressure washed it off.
The time now is 08:22 PM.
