Chevy 350 conversions - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > Chevy 350 conversions
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueSteering Stabilizer Brackets...
Unread 02-18-2010, 09:51 PM   #1
nedmoore
nedmoore's Avatar
1982 CJ7
Let's see your chevy 350's! Under the hood pics too! Please add descriptions of the tranny and the biggest problem that you had with the swap....
I added some pics since I started this thread. Just snapped a couple with my cell phone. Note the wiring near the new master cylinder and booster. I am trying to decide whether to replace or sand and paint the headers.
nedmoore is offline   Reply With Quote Quick reply to this message
Unread 02-19-2010, 04:50 PM   #2
jkl
Almost finished SBC w/ th350 and NP205. My biggest problem so far is that the transfercase hangs low
'13 10th Anniversary Unlimited Rubi
'05 LJ on 35s
1 Ton XJ on 40s...went up in flames :(
1 Ton Scrambler Build Thread:"Project Taildragger"
...now parting out
jkl is offline   Reply With Quote Quick reply to this message
Unread 02-20-2010, 08:24 PM   #3
nedmoore
nedmoore's Avatar
1982 CJ7
Thanks JKl, mine is too low too! You should see the home made crossmember from the po! It is about to go...
Come on guys post some pics, I know there is more out there!
Unread 02-21-2010, 09:44 AM   #4
StantonYJ
Did you cut that lip on the firewall to make more clearance?
StantonYJ is offline   Reply With Quote Quick reply to this message
Unread 02-21-2010, 09:46 AM   #5
StantonYJ
I wanna know if you cut that lip on the firewall and what kind of ignition and distributor you are running?
It looks great
JEEP- Just Everyone Else's Parts
Unread 02-21-2010, 11:10 AM   #6
jkl
Did not cut anything and HEI distributor. I'm at work today, but will get a pic tomorrow to show the rear clearance.
'05 LJ on 35s
...now parting out
Unread 02-21-2010, 11:17 AM   #7
StantonYJ
thanks bro is that a cj or yj ??
Unread 02-21-2010, 12:26 PM   #8
jkl
cj
'05 LJ on 35s
...now parting out
Unread 02-21-2010, 02:19 PM   #9
jeepin1995
350, 700R4 trans, NP231C/J t-case..... hardest part is STILL the wiring (a year later)
From this:
To this!!:
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2010, 02:57 PM   #10
jkl
Originally Posted by jeepin1995 View Post
To this!!:
What kind of headers?
'05 LJ on 35s
...now parting out
Unread 02-21-2010, 05:03 PM   #11
yj35s
I also did the conversion with the 350 and 700R4 and factory t-case. I am having a HUGE problem with the wiring also about a year later. It does perfect but when I turn the lights on the alternator gets so hot it burns the belt into pieces. The next step is a one wire alternator straight to the battery. Other than that I love it, it isn't nothing like walking up to it and jumping in and cranking it up and getting everybody to look. the headers look like headman block huggers thats what i used and love it.
-1990 Wrangler- 5 inches, 35x12.50, chevy 350, 700R4, line-x tub
-2003 Grand Cherokee- 2''BB and 265/75 BFG all-terrain (daily driver)
yj35s is offline   Reply With Quote Quick reply to this message
Unread 02-21-2010, 05:25 PM   #12
jeepin1995
headers are the hedman 350 into a jeep conversion headers
i had an uncapable low amp alternator.....so i bought a new one from summit racing:
Summit Racing SUM-G1667A - Summit Racing® Chrome Alternators - Overview - SummitRacing.com
it's great. 100 amps, one wire (hook it to the big lug on the starter) thats it. has a self exciting internal regulator..... with all my lights, radio, electric fan, and heat on, it still puts out 14 volts charging(had it tested today) highly recommend!
Unread 02-21-2010, 07:41 PM   #13
yj35s
thanks jeepin1995 I will consider that alternator the main thing now is saving the jeep fund back up. It is very aggravating not being able to drive the jeep at all at night. Also, what style kick down cable did yall use for the 700R4 I cant get mine adjusted right it shifts alittle funny when it gets warm. I think it might be the crapy rebuild I got for cheap. Live and learn I guess.
Unread 02-21-2010, 08:27 PM   #14
jeepin1995
lokar kickdown cable from summit
Unread 02-21-2010, 10:13 PM   #15
hookedupinc
I would show you some pics, but this joint won't let me yet ..If you can see my profile pic there is one of my engine. I would love this thread to stay alive, and any other 35o conversion threads that we can get going, cause I and alot of others still need some help getting finished up.
"Aw, jis taws a D-sisty aNNa SEE-fortene in air, an-U kin hit da mudHO wit me and Bubby dis weakin."
http://www.jeepforum.com/forum/f12/project-jevy-984905/
hookedupinc is offline   Reply With Quote Quick reply to this message
