Anyone Running 36's on a HP Dana 30??? PICS - JeepForum.com
post #1 of 10 Old 08-15-2011, 07:53 AM Thread Starter
-jb-
I'm currently in the process of swapping in a HP 30 from an XJ. I've been needing to regear from 3.73's for awhile. I just put 36x13.50 Iroks on my TJ. A friend gave me a XJ 30, so I went ahead and bought 4.88 gears for the Jeep. Then bought a YJ 30 axle from a friend that had a Aussie locker in it but more importantly High Steer with drilled passenger knuckle with a bolt on arm. Kinda of like the Steering on a WJ. It's all DOM tubing an heim joints. Resembles the Tera-Flex kit. At this moment I am brain dead on what setup is on it. Going to call my buddy just to verify which steering setup it is.
I found out quickly (and I knew in the back of my head it was going to happen) that 36's and stock steering don't like each other. After straighting out a U-shape tie rod, I found new steering. The stock steering lasted pretty well on 35's for about a year with only a few smaller bends.
Who is running 36's on a HP 30, pics? Hows it treated you? I'm more of a slow crawler on the trails and light on the skinny pedal till I need it. This is just a temp setup till I finish building the 1 ton axles I have, purchase everything else I need to get these axles underneath my Jeep, get larger tires and a DD to drive....right now I drive my Jeep everyday.
Pic of the Jeep on 36's. Getting ready to swap the HP 30 in here in the next few weeks
Yellow Jeep Member #42
01 TJ Sport
00 TJ Sport
-jb- is offline
post #2 of 10 Old 08-15-2011, 08:07 AM
jakemnm848
High pinion D30 is stronger than a low pinion so if the low pinion is holding up I don't see why it wouldn't.
jakemnm848 is offline
post #3 of 10 Old 08-15-2011, 08:09 AM
sail78385
I ran 37's on my LJ forever -then I sold the jeep. Never had any problems. Its all how you drive it I guess. Dana 30 4.88 gears
Red Unlimited Golden Eagle
sail78385 is offline
post #4 of 10 Old 08-15-2011, 08:17 AM
95wrangler4life
I was running 35's, now running 36's SX's, last ride at the park in March I tried testing to see if I needed Chromo's yet up front, and my answer was "not yet" followed a built TJ all around the park without issues, and even got a little stupid with it on Crawl Daddy. I do need to change my steering but I have not bent it yet. 4.88's and locked make a huge deal, even with my 2.5 i just let it idle over most of the trails.
95YJ 2.5 AX5 NP231 HP30 4.88 and aussie, 8.8 4.88 mini spool, 4" RC, 1.5" Boom shackles, 1" BL, 1" rear stretch, 36 12.5 15 TSL SX's, trimmed front fenders, bedlined exterior, comp cut coming soon!
Build thread:
95wrangler4life is offline
post #5 of 10 Old 08-15-2011, 08:18 AM Thread Starter
-jb-
That's what I figured. Just want it to last for awhile till I can upgrade. I'll carry spare d30 shafts also just incase.....I don't question the 44 in the back. But I don't slam the gas either.
01 TJ Sport
00 TJ Sport
-jb- is offline
post #6 of 10 Old 08-24-2011, 08:42 PM
TurboTPI
I had 36x14.5 TSL's on my 93 YJ 4.0L/5 spd with a HP 30. I beat the living **** out of it. I broke drive shafts (front and rear) but never did my front axle give me a problem. Everyone used to tell me i'll brake it just looking at it wrong with anything bigger than 35's on it. Well, i dont know if mine was a freak or what, but not one problem.
02 WJ Limited 4.7l HO-stock (Hers)
95 ZJ 4.0 Turbo-up 5.5 on 33x12.5's, Ford 8.8 w/Artec truss (His)
92 Firebird Formula custom turbo setup (His)
09 Polaris Dragon 800 (His)
TurboTPI is offline
post #7 of 10 Old 08-24-2011, 09:18 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
as the good folks over on Pirate say...
36's are not that big...
2016 TJ of the Year
Founder, Offroad NC
Follow our journey:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
EugeneTheTJ is offline
post #8 of 10 Old 08-24-2011, 11:33 PM
redrubi03
mine has been on 37's with 4.56 for 7 years and no problems. i have chromos tho. but ive heard 37's are still big for chromos but like i said, havent had a problem yet.
redrubi03 is offline
post #9 of 10 Old 08-25-2011, 07:48 AM Thread Starter
-jb-
I'm more on the same mindset as the Pirate folks are. To me 36's aren't that big, reason why I am building 1 tons as I type. But for the mid, I'm running your normal setup and switched to 36's. I'll be running 4.88's and a locked front. Not sure what to do with the rear, may just leave it alone as this is a DD right now. I don't want to put a lunchbox locker in the rear because of it's driving characteristics on the street but I don't want to spend much more on the axles for a selectable locker. If I could find a factory dana 44 lsd, I'd throw that in there just to have something better then open........I'd rather put the money in building the 1 ton axles and getting my Jeep ready for those.
01 TJ Sport
00 TJ Sport
-jb- is offline
post #10 of 10 Old 08-25-2011, 04:57 PM
creepycrawly
creepycrawly's Avatar
I have been running 35x13.50 BFG krawlers on my hp30 for a whole now with no issues and it is locked as well. I am on stock shafts and intend to stay that way just because they are way cheaper and easier to replace than ring and pinion. The 35 krawlers are huge for 35's and are heavy and sticky! I am just not a throttle jockey!
You can't be first, but you can be next!
creepycrawly is offline
On 36's or 38's?? skinpin Jeep Picture Requests 2 07-06-2011 08:41 PM
all yjs running metalcloaks post pics here bft89yj Jeep Picture Requests 1 05-20-2011 04:27 AM
Are you running these? Pics of 33X12.50X18 on a TJ fdk1200rs Jeep Picture Requests 8 02-25-2011 10:37 AM
XJ on 36's chigg84 Jeep Picture Requests 22 01-13-2009 04:09 PM
cj5 on 36's jeepboy90 Jeep Picture Requests 0 12-29-2005 09:39 PM
