Any XJ on 36" IROK's - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > Any XJ on 36" IROK's
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 10-20-2008, 12:38 PM   #1
Tone89
1994 XJ Cherokee
I plan on up'ing to 36's and maybe 6" of lift, would like to see some examples if i could!
1994 XJ
Tone89 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2008, 12:42 PM   #2
ktmracer419
1997 XJ Cherokee
ill have em' in a couple weeks, just waiting on 2 wheels
( i run about 3" lift though)
97 xj
44 front, detroit, alloyed
60 rear, detroit, 35 spline alloyed
35" beadlocked km2's
3" midarmed
more bells and whistles than you can shake a stick at
ktmracer419 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2008, 12:46 PM   #3
Tone89
1994 XJ Cherokee
hmm, your cut up and bumpstopped right?
1994 XJ
Unread 10-20-2008, 03:42 PM   #4
Arcticcat843
dakuda is a god
Arcticcat843's Avatar
1980 CJ5
let us know how they are.....Im looking at them for my next tire...(did you get the radials or bais ones?)
Arcticcat843 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2008, 07:45 PM   #5
ep191
haha nice i get to whore mine out, 8 inches of lift on 15x10's 3.75 backspace
ep191 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2008, 07:48 PM   #6
ep191
ive got bias and i love them (my brother has radials, almost the exact same except his are less rounded), very well rounded offroad tire, probably not as good as a creepy crawler or bfg crawler on the rocks, or a tsl or bogger in the mud, but a very good mixture of both very sticky tread compound.
Unread 10-20-2008, 09:06 PM   #7
Tone89
1994 XJ Cherokee
yeah im gonna get the bias plys cause ill probly be towing the h'eep anyway. what axles u runnin ep191
1994 XJ
Unread 10-20-2008, 10:29 PM   #8
ep191
well im actually throwing a full width pair of high pinion d44 front d60 rear because its going to be almost all trail rig. I ran it for about 5-6 trail rides on the d30 and chrys. 8 1/4 but neither were locked. Since you have the 35 rear you definetly would need at least a 44 or 8.8 in the rear and could proly get away with the 30 if you sank some serious cash into it (truss, alloy shafts, u joints)
Unread 10-21-2008, 09:56 AM   #9
blk88
1988 XJ Cherokee
RK 8" LA and 37" Iroks.
blk88 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2008, 12:37 PM   #10
ep191
just to let you know the 36's arent a true 36". They are way closer to 37's listed something like 36.8 on the website i saw.
Unread 10-21-2008, 01:06 PM   #11
Tone89
1994 XJ Cherokee
okay thanks a lot, im turned onto these tires now..
1994 XJ
Unread 10-21-2008, 06:13 PM   #12
ktmracer419
1997 XJ Cherokee
only have 2 wheels, but i mocked up a couple today
these are the 36" bias, measure out to nearly a 37 though
went to get flex pics but instead got this:
97 xj
3" midarmed
Unread 10-21-2008, 07:05 PM   #13
breckboarder55
How did you manage to do that, with a D60? That is some kind of flex pick!
"honey, I'm going to run to the... "store?""
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2008, 07:23 PM   #14
Arcticcat843
dakuda is a god
1980 CJ5
seeings how there is only like 20ish splines...im pretty sure its not from his 60
but still, there has to be a story behind it!
Unread 10-21-2008, 07:41 PM   #15
ktmracer419
1997 XJ Cherokee
its a alloy 44 stub shaft
i drove over a 6" pebble heard a pop then had 3 wheel drive
i probably fractured it on the previous run and it just let go now
97 xj
3" midarmed
