All TJs with ford 8.8 - Page 3 - JeepForum.com
post #31 of 58 Old 03-25-2011, 11:17 AM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
My 8.8 (4.88 LSD) before going in.
No wheeling shots with the new axle yet, and I am still on 33s
2016 TJ of the Year
Founder,
EugeneTheTJ is offline
post #32 of 58 Old 03-25-2011, 02:48 PM
djflyy
Ordering mine from ECGS since I don't have access to a welder for the brackets.... I've heard nothing but great things about the company, so hopefully that will go smoothly!
djflyy is offline
post #33 of 58 Old 03-25-2011, 07:12 PM
turbojoe
what are you guys spending on putting these together? 250 for mount, 200-300 for axle?, around how much would a hop charge to mount these brackets on?
WRANGLER
4.0L
Sport
Jeep
turbojoe is offline
post #34 of 58 Old 03-25-2011, 07:49 PM
EugeneTheTJ
Tar Heel
I paid 900 for an 8.8, 4.88, LSD, TJ brackets AND a LPD30,4.88 off of CL
2016 TJ of the Year
Founder,
post #35 of 58 Old 03-25-2011, 08:16 PM
OZFive
Can someone explain the differences in a Ford 8.8, a Dana 44, and a Dana 60?
Are there certain levels of durability to each. I understand a Dana 60 is more durable than a 44 but where does the 8.8 come in on the scale of toughness?
1998 Jeep Wrangler Sahara
Black w/ Spice Sahara Interior & Black Soft top.
Is my first Jeep!
OZFive is offline
post #36 of 58 Old 03-25-2011, 08:21 PM
GeoKR
Runnin 35 x 14.50 boggers
98 Sahara 4.0 5spd - 5" W/ 35" Boggers, Rubi 44 Front Locked & Chromo'd w/ 5.13's, 8.8 Rear Locked w/ 5.13's, NV241OR, Woody Shafts, Flat Skid, Tuff Designs Front Bumper, EPi9.0 W/ Blue steel
I spent most of my money on women, booze, and toys, the rest I just wasted.
GeoKR is offline
post #37 of 58 Old 03-25-2011, 09:50 PM Thread Starter
Calven727
here is some info on the strength
http://www.jeepsunlimited.com/forums...d.php?t=371713
ford 8.8 is way cheaper than d44 or d60 and still has the same lug nut pattern as your d35 and d30.
The axle shaft strength tested by Warn IndPosted on jeepsunlimited.com)
F8.8= 6,500 (lb. ft.)
D44= 4,600-5,000 (lb. ft.)
D35C= 4,000-4,300 (lb. ft.)
And from my reading from Crawl magazine, if you get the super 88 kit it will increase the strength by 44% and make the 8.8 into d60 country as far as shafts go.
Calven727 is offline
post #38 of 58 Old 03-25-2011, 09:51 PM Thread Starter
Calven727
that thing looks sick. more pics would be great
post #39 of 58 Old 03-25-2011, 10:00 PM
djflyy
You can find 8.8s for as low as $100 depending on where you are in the country. Check out www.car-part.com for your local inventory and junk yard supplies. Brackets can be $250-350 depending on where you get them (M.O.R.E. , East Coast Gear Supply, others etc) and then I'd assume a shop would be a hundred or two depending on if you know the welder. The axle needs some grinding done to get the stock mounts off before anything can be done to put TJ brackets. It may be easier to buy a pre-built one, check out East Coast Gear Supply's 8.8 bolt ins.
http://eastcoastgearsupply.com/c-916...ssemblies.html
djflyy is offline
post #40 of 58 Old 03-25-2011, 10:12 PM
krazymatt
Here's mine. I'm running a 8.8 4.10 LSD off a 1998 Explorer. I don't really wheel too extreme, but I couldn't put money into the turdy 5 when it came time for a regear. I am runing adjustable rear uppers, a sye and cv drive shaft and front and rear adj. track bars all on a 4" Pro Comp lift and Rancho 9000's that were on the Jeep when I got it. I'm getting there, my next project is to repaint my flares and build some custom bumpers soon.
krazymatt is offline
post #41 of 58 Old 03-26-2011, 09:43 AM
djflyy
If this is a recent pic, ditch the bumper floaties! 3 or 4 torx screws per side, and it looks so much cleaner without them!
djflyy is offline
post #42 of 58 Old 03-26-2011, 11:57 AM
GeoKR
Thanks, I just put the boggers on, thats the only pic I have with them. I'll try to get some more this weekend.
GeoKR is offline
post #43 of 58 Old 04-03-2011, 09:58 PM
krazymatt
Yeah, I agree. I actually removed them about a month ago. Pic is from last summer.
post #44 of 58 Old 04-03-2011, 09:59 PM
krazymatt
I agree. Your Jeep looks freakin mean!
post #45 of 58 Old 04-03-2011, 10:11 PM
alex_c
IMHO this is the best deal on a complete install solution.
http://www.knowwhere2jeep.com/know-w...ler-tj-lj.html
Wish I found it before I bought my brackets!
'97 TJ Sport
33x10.5 KM2, 8.8 LSD w/discs and RHM bracket kit, HP D30 w/homemade diff armour, 4.10 gears, 2.5" junk yard lift, Rusty's 1" BL/MML, AA SYE/CV Shaft, XRC Sliders, V8 ZJ steering, CB, GPS, some other crap.
Buy it then build it, or buy it built and end up tearing it apart and building it anyway. Which one do you think is easier?
alex_c is offline
Ford GPW 1942 aamir567 Jeep Builds 114 10-09-2014 01:46 AM
1997 TJ Jeep build, Installing 1979 Ford Dana 44 Front Diff, Ford 9" Rear Diff psycoticredneck Jeep Builds 6 12-03-2010 01:17 PM
ford 8.8 with 33s Peej03 Jeep Picture Requests 15 05-07-2010 07:40 PM
Ford 8:8 Barrio Jeep Picture Requests 11 07-02-2008 02:22 PM
My ford getting it this morning kairo Jeep Builds 13 03-19-2008 10:07 AM
