35x18 or 37x20?! - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > 35x18 or 37x20?!
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitEngo winches available at www.rockridge4wd.com! Free shippFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 08-21-2014, 11:32 AM   #1
Spicoli
35x18 or 37x20?!
I'm trying to decide between the two.
Looking to go with a 3.5 or 4" lift depending on the tire size, any photo reference help would be greatly appreciated.
Spicoli is offline   Reply With Quote
Unread 08-21-2014, 11:45 AM   #2
141
Neither! Unless you are going for the ghetto hoopty look.
2012 Rubicon JKUR: 4" Tera Flex Long Arm, Fox 2.0 Shocks w/resi, Fox Stabi, Yukon 5:13's, Evo C gussets, Evo Magnum Sleeves, Evo Rockstars, LOD Stubby Bumper, Poison Spyder Rock Brawler Rear Bumper/Carrier,Poison Spyder Sliders, Poison Spyder EVAP Skid, KMC Strikes on 37" Nitto Trail Grapplers
141 is online now   Reply With Quote
Unread 08-21-2014, 12:38 PM   #3
Spicoli
Neither 35x18 or 37x20 would be relatable to your aforementioned picture...
For instance:
3.5" - 35x18
4.5" - 37x20
Unread 08-21-2014, 12:46 PM   #4
141
Less rim, more tire is better for off road use. 37's will require new gearing, beefing up your C's and sleeving the front axle on the JK's. It really depends on what you're looking to do with your Jeep.
Check out this thread...lot's of different set ups to check out -
http://www.jeepforum.com/forum/f96/l.../index253.html
Unread 08-21-2014, 12:48 PM   #5
Spicoli
I've heard about 37s requiring new gearing -- ballpark, what would something like this end up costing?
Unread 08-21-2014, 02:03 PM   #6
141
Prolly around $1,200-$1,500. That would be gears, master install kit and labor all in. Check with some of the local shops. Make sure you put a couple heat cycles on them before a long trip. Swap the oil out at 500 miles.
Unread 08-23-2014, 11:56 AM   #7
blackwidow03
2010 JK Wrangler
35's on 18" wheel
37's on a 20" wheel
I have 35" on 20" wheel and it could use more sidewall, but works fine for what I do.
blackwidow03 is offline   Reply With Quote
Unread 08-24-2014, 10:13 AM   #8
Spicoli
Originally Posted by blackwidow03 View Post
35's on 18" wheel
37's on a 20" wheel
What size lift do you have?
Unread 08-24-2014, 08:43 PM   #9
blackwidow03
2010 JK Wrangler
I have a 4" with flat fenders. I'm running 35" nitto trail grapplers on 20" rock star.
After seeing that black 4 door with the mud grappler, I will be getting those 37's next!
Unread 08-24-2014, 11:12 PM   #10
Spicoli
Hahaha, hard isn't it?
