35s or larger on 3" or less (LCG Jeeps) - Page 154 - JeepForum.com
 16Likes
post #2296 of 3464 Old 05-07-2013, 11:51 PM
newman08
newman08 is offline
post #2297 of 3464 Old 05-08-2013, 08:02 AM
michigan37
2010 JK Wrangler
Originally Posted by newman08 View Post
What size bump stop extensions do you have on yours? I'm getting ready to install a 2 1/2" and am trying to figure out what size extensions I need to get.
michigan37 is offline
post #2298 of 3464 Old 05-08-2013, 08:15 AM
TURBevO8
Here is mine...
2" Teraflex coils, 1" BL, RE Longarm kit, Teraflex HD DOM Track Bar, Teraflex High Steer Kit, 35" Kevlars, Atlas2 4.3:1, D30 w/ ARB and 4:56, D44 w/ARB 4:56.
This set up works great! I am really happy with the way it turned out. I moved from the 5.5 RE Coils down to the 2" coils and it made a night and day difference in the way this thing wheels/climbs!
I will shortly be adding a full set of Metalcloak Overlines.
Nice Jeep! Looks like your coils are unseating. I find my OME 2.5 HDs to unseat at about 4.25" down. I am really debating 3" Currie/Savvy and cutting the upper spring perch and welding it up higher to get the amount of total lift I want while having a spring that can expand further downward. Do you happen to know about where your current 2" springs are unseating with those shocks? Thanks!
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is offline
post #2299 of 3464 Old 05-08-2013, 01:41 PM
newman08
I am running the stock upper cups/inserts and I have a 3" lower bump pad on the bottom. This gives me approximately 3-3.5" of up travel in the front. I had to limit it a lot just because of the steering setup that I am running. I do have some rubbing issues in the front when I'm am turned hard right or left and at full stuff... solution: Metalcloak Overlines!!
The rear is not as critical... I only have about an inch of bump extension on the rear... So I have approximately 4.5" of up travel in the rear (no rubbing issues).
newman08 is offline
post #2300 of 3464 Old 05-08-2013, 01:45 PM
newman08
I don't currently have those measurements but I will work on getting them for you.
I will say, I don't have any problems with my springs even though they do un-seat a little bit...
newman08 is offline
post #2301 of 3464 Old 05-08-2013, 01:58 PM
newman08
Here are a few shots of my steering set up for those of you wondering how this worked out with 2" springs (works great). About 3" of extra bumpstop to make it work. So I have about 3" of up travel. And I am running 10" travel TeraFlex shocks which gives me a lot of down travel (I will get a measurement soon).
newman08 is offline
post #2302 of 3464 Old 05-08-2013, 02:02 PM
newman08
Here are some more shots...
newman08 is offline
post #2303 of 3464 Old 05-08-2013, 02:05 PM
newman08
Here it is before I dropped it... It is so much better now in every way!
newman08 is offline
post #2304 of 3464 Old 05-08-2013, 02:49 PM
TURBevO8
Is the clearance between tie rod and track bar the limiter on the DS?
TURBevO8 is offline
post #2305 of 3464 Old 05-08-2013, 06:58 PM
newman08
Sorry, I'm somewhat new to the forum lingo... What does "DS" mean?
newman08 is offline
post #2306 of 3464 Old 05-08-2013, 07:03 PM
duc202
I think they are referring to the driveshaft
White Jeep Club member #253
duc202 is offline
post #2307 of 3464 Old 05-08-2013, 08:52 PM
Jankoid
Normally that means driveshaft, but I think he means driver's side in this context.
Jankoid is offline
post #2308 of 3464 Old 05-08-2013, 09:02 PM
TURBevO8
Yeah. Sorry about that.
TURBevO8 is offline
post #2309 of 3464 Old 05-08-2013, 09:18 PM
newman08
No worries... It looks like it would but my bumpstops prevent it from making contact. Actually doesn't even come close. I did a ton of research before I went with this setup due to the fact that I thought my drag link would make contact with my frame but it all work great! I did have to modify the TeraFlex track bar bracket slightly... I basically lopped off the bottom 2" of the bracket so it would not make contact with my tie rod.
newman08 is offline
post #2310 of 3464 Old 05-12-2013, 09:01 AM
TURBevO8
I want more pics. I am sold on highlines purely based on function but fear they will look odd with 35s if I do not go lower. I have seen 2 or 3 rigs on this thread but would love to see some more. Also, more MTR-Ks. I wanted PBRs forever but bang for the buck the Goodyears are just tough to beat. I was dead set on getting Rokmen fenders this summer but now with them on backorder forced me to think about a plan B. So thought the Genright aluminum would be nice. Look great, aluminum for weight and will never rust, and do not have to weld them myself which may be nice. So, in short, please post up more highline on 35s pics please!
TURBevO8 is offline
37" or larger minileprechaun Jeep Picture Requests 53 04-30-2015 09:49 AM
7" or Larger Lift Jeep4L1fe Jeep Picture Requests 37 07-03-2011 01:40 PM
36" and larger tires Brads_nky_yj Jeep Picture Requests 17 08-29-2008 04:50 AM
LJ's with 6" pocket-style flares w/ 32" or Larger Tires NavinRJohnson Jeep Picture Requests 0 10-04-2006 12:20 PM
How about some Monster Jeeps, 40" or larger JeepNazi101 Jeep Picture Requests 35 09-12-2006 08:01 PM
