Quantcast 35s or larger on 3" or less (LCG Jeeps) - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > 35s or larger on 3" or less (LCG Jeeps)
Old 02-03-2009, 08:20 AM   #1
MattGATRTJ
GATR Member #1
MattGATRTJ's Avatar
I want to see what you have. Looking for ideas. My goal is to run 35s w/ 2" suspension and 1" body, tube fenders, limit the up travel, cut the rear a bit.
BTW I have a TJ, I dont care to see other jeeps.
MattGATRTJ is offline   Reply With Quote
Old 02-03-2009, 08:30 AM   #2
spyder6
Just violated my Parole
spyder6's Avatar
37's on 3" of lift
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 02-03-2009, 07:35 PM   #3
jonnyboy2001
http://www.jeepforum.com/gallery/data/8/jeeptj1.JPG
homemade highline and 2" lift on 37's. this is before i did any cutting in the rear.
1998 Jeep Wrangler
305 v8, nv3500 5spd tranny, np207
d30, 8.8, 4.11 gears
2" coils front, cj 4" leafs rear, rancho rsx 2.5" shocks
homemade highline tube fenders
37x12.50x17 tires
jonnyboy2001 is offline   Reply With Quote
Old 02-03-2009, 07:41 PM   #4
6stringboarder
i dont get it. it seems to me that this would make the jeep basically usless. i mean those jeeps have almost zero wheel travel
BLUE JEEP CLUB #163
Michigan Jeepers #48
Mud Boggers #22
4 cyl TJ World #27
Boyscout Jeeper #15
OlllllllO
6stringboarder is offline   Reply With Quote
Old 02-03-2009, 07:48 PM   #5
lukethedork
My jeep has no extensions on the bumpstops, So I'm still getting 100% of the stock uptravel.
I also have shocks suited to 2" of lift (OME), So I'm getting an additional 2" of down travel.
So with my 35" tires I'm maxing out my 2" OME shocks (in both compression and extension). This is the same as someone with 31" tires and 2" OME shocks would be doing...
Can you really not see the benefit of bigger tires?
lukethedork is offline   Reply With Quote
Old 02-03-2009, 07:50 PM   #6
CCJ
Some people don't always understand.
It's about clearance not flex.
CCJ is offline   Reply With Quote
Old 02-03-2009, 08:12 PM   #7
lukethedork
Well my jeep has the same belly clearance as a jeep on 31s and 2" lift. It also has a better approach, departure and break over angle, and 2" more clearance under the diffs. The only clearance I need more of right now is belly. Which a tummy tuck will do for me.
Why would one stay on 31s when there is room for 35s???
If you want 6" of lift then get 6" of lift... But don't get 6" of lift BECAUSE you want to fit 35s... You can fit 35s with 3" of lift and still have the exact same wheel travel as someone with 33s and 3" of lift. (except you got another 1" of clearance over him)
edit: What I'm trying to say is that clearance can be had from other things apart from lifting your jeep 6".
If you need more approach and departure then push the wheels back/forward further.
If you need more break-over then tuck the tummy up.
More sill clearance? boatside it.
Old 02-03-2009, 08:36 PM   #8
breckboarder55
Wow a V-8, 37"s, and a D-35? Talk about a ticking time bomb
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
02 Toyota Celica GT-S-DD/beater
breckboarder55 is offline   Reply With Quote
Old 02-03-2009, 10:06 PM   #9
jonnyboy2001
yeah, i've heard that before. i'm running open diff's and an auto tranny for now, so that with a little throttle control should help it last for now. also, my 305 is wounded (sticking valve). we'll see how long the rear lasts after i swap to the 350 i built for it.
1998 Jeep Wrangler
37x12.50x17 tires
Old 02-04-2009, 02:02 AM   #10
Turner
Unforunately some guys who haven't been around wheeling long think that the flex is the only way to wheel... Those Ramp queen days are a thing of the past. It doesn't matter how much flex you have. 3-4 inches uptravel is optimum, droop is where its at. Thats why I personally am a fan of leafs, but Lukethedorks setup is amazing. If I had a TJ that is very similar to what I would do. Proper wheel placement, ground clearance and a drivetrain that can handle your setup will take you a long long way. Low Center of Gravity rigs aren't new at all but it seems as most large companies steer you away from small lifts. Offering 4, 5, 6 inch lifts and higher are mainstream and for some reason sell. The more you research the more you will want to stay around the LCG. A jeep on 35's can tackle almost any trail in the continental U.S.
--Turner--
2006 Jeep TJ
1982 Toyota Pickup 20r/22r Hybrid, 5.29s, Lockrite frt/spool rear, Longfields, Hysteer, discs, armor, dents, smiles.
1970 Ford Bronco302, dana 30, 9", 3 on the tree, show stopper.
Turner is offline   Reply With Quote
Old 02-04-2009, 08:25 AM   #11
alex71
Cant be done Matt
2001 jeep wrangler sport / Waggy 44 /FORD 8.8. lockright/ 4.88 / 3/2'' lift,Stretched to 100.5/ Warn x8000i / 35in BF KM2's / AtoZ rockers, cage,/ Poison spyder crusher corners.
Vote for TJOFTY!
http://www.jeepforum.com/forum/f9/tj-year-contest-2010-vote-now-contest-has-started-1140918/index9.html
alex71 is offline   Reply With Quote
Old 02-04-2009, 09:09 AM   #12
frumpy
Not 35s, but no lift. I plan on going to 35s when I eventually regear and swap an 8.8 in and kill my 33s (so 2-3 years)
More trimming and less flares to come during spring
2002 Dodge Dakota quad cab V8
2011 Dodge Grand Caravan
frumpy is offline   Reply With Quote
Old 02-05-2009, 12:28 PM   #13
MattGATRTJ
GATR Member #1
MattGATRTJ's Avatar
Thanks for the pics guys. Mine is still a work in progress. I dont want anymore lift that is for sure. Limiting the up-travel doesnt limit your down travel which is most of your flex anyways. Its also a small price to pay for the extra clearance.
Here is my jeep.
35" KM2s and 2.5" of lift.
Old 02-07-2009, 07:01 AM   #14
frumpy
Looks good but you look quite limited on the up travel. Why not tube fender or flat fender the front and trim the rear a bit?
Any flex pics with the current setup?
Old 02-07-2009, 08:24 AM   #15
Gabe
Yeah, that doesnt look good. Just looks like you have too big of a tire for the lift and that will probably hurt you more than help you.
Originally Posted by Rubi22
Holy ****, did someone log onto Mean Fish's account and say something thoughtful?
Gabe is offline   Reply With Quote
Glock Forum
