35" vs. 33" - JeepForum.com
post #1 of 11 Old 07-12-2005, 02:58 PM Thread Starter
jmiller
35" vs. 33"
Does anyone have a picture of 35 next to 33 with a person in the picture. I want to upgrade tires, but I do not want to go to big, or to small. Thanks
jmiller is offline
post #2 of 11 Old 07-12-2005, 03:14 PM
cspoffroad
Well here is the best pictures i have. They arent in the same picture
Rubicon on 35's
TJ on 33's
98' Jeep Wrangler Sahara
Skykacker 4inch, 33x12.50 BFG M/T's, kilby steering skid, optima red top, flowmaster 40 series, airaid intake and TBS, bestop bikini and halftop, lock-right in Dana 30
"Are you locked up?
Yup, both doors!!!!"
cspoffroad is offline
post #3 of 11 Old 07-13-2005, 04:31 PM
themongoose5
4" 4WD lift. 33s
http://www.desta.info/temp/jeep%202.jpg
82 cj7 4" 4wd lift 33x13.5 on 15x10 polished alum rims. living jeep and loving it <><
themongoose5 is offline
post #4 of 11 Old 07-14-2005, 12:07 PM
97TJGUZZY
97TJGUZZY's Avatar
32s on the tj
35s on the xj...
For info on outdoor adventures in South Carolina check out
97TJGUZZY is offline
post #5 of 11 Old 07-14-2005, 12:12 PM
richnev
2014 JK Wrangler
Rubicon on 35's
TJ on 33's
What are the lifts on those two? I think it would help him out more if you included the lifts
05 Jeep Wrangler X .... RIP
07 Jeep Wrangler Unlimited X ...... let the build begin
ARMY TEAM MEMBER #4
Originally Posted by ge2 View Post
I just make a BOOP BEEP sound with my mouth (really loud) as I walk away from the jeep, and point the key at it.
Originally Posted by her94yj View Post
lets put it a way a kids will relate......its like a hooker.......... SURE a 15 dollar handy from a detroit toothless 60 year old can get it done....... but NO where is it as nice as the $5000 an hour goddess from vegas or hollywood
....... dont be that fat guy on the beach in the speedo you dont want to be "that guy"
richnev is offline
post #6 of 11 Old 07-14-2005, 12:17 PM
LynchMOB
Originally Posted by 97TJGUZZY
32s on the tj
35s on the xj...
WOW, How did you get those up their..... N E V E R M I N D their JEEPS!!! Great picture!!!
2005 TJ Unlimited Solar Yellow (STOCK)
Parrothead Jeepers Union Member #20
Yellow Jeep Club Member #314
LynchMOB is offline
post #7 of 11 Old 07-14-2005, 01:49 PM
supaasianpdjr
Just go with the 35's because eventually you will want to go bigger. Just save yourself the hassle... Just my .02 cents
supaasianpdjr is offline
post #8 of 11 Old 07-14-2005, 02:01 PM
cspoffroad
The Rubicon has a 5.5 Rock Krawler LA (triangulated rear end) w/ 35
The TJ (mine) has a 4 inch Skyjacker SA with 33's
"Are you locked up?
post #9 of 11 Old 07-14-2005, 02:28 PM
red99tj
red99tj's Avatar
I ewopuldnt say that w/o knowing what he is running... what gears hes running. what axles he has, steering, etc etc. Jumping to 35's requires more than one thinks.
If hes really asking this question then i think he should run 33's if its a choice between the 2
This post puts it in laymens (sp?) terms (talking about 35's):
Originally Posted by PDX_XJ
Boggers are some big, wide, heavy tires.
That new pair of shoes isn't going to fit on your Jeep's current feet (err, rims). You should get a wider rim (10") with less backspacing, or else your Jeep will stand around rubbing it's shoes against it's ankles.
Those heavy tires are also going to make your Jeep want to attack other cars. Sporty little go-fast cars will probably cut you off and slam on their brakes. I don't know why, but they do. You want to prevent your Jeep from seeking retaliation, so you are going to need some kind of brake upgrade.
They also have a tendency to make your Jeep lazy. Much like how lions (the king of the jungle) like to lie around all day... when you're Jeep becomes king of your neighborhood, it will begin to take it's sweet time getting places. You can fix this by regearing your differentials. There's much debate about what is perfect, but everyone agrees the stock 3.07 ratio is too high.
They are also going to want to make your Jeep hate itself. Big heavy tires will cause your Jeep to cause itself harm. Primarily, it is going to slit it's wrists (by that, I mean you are probably going to break your tie-rod). You are going to want to beef up your steering.
Sometimes, you may get unlucky and find that your Jeep just isn't strong enough to keep running. You need to give it some stronger legs ( a stronger rear axle) if your current legs (Dana 35) aren't strong enough.
You should also cover that god-awful midriff with some armor. How much? Well it depends. If your Jeep wants to go to war, get it some rockers, a steering box skid, an oil pan skid, and a gas-tank skid at the least, or else the enemy will gut your Jeep with their sharp weapons (rocks).
Don't forget your life-line! - a tow rope will be most helpful.
Later, you can accessorize.
Frank
red99tj is offline
post #10 of 11 Old 07-14-2005, 09:39 PM
crawldit
crawldit's Avatar
How about 33's and 34's =) This is with 6" of lift
2005 Rubicon :
4.0 Automatic,4.11 gears,4:1 Transfer Case
Teraflex 3" Coils,Rancho 9000x's,35" KM2's,(fenders...what fenders?), Cobra CB, Lowrance Baja 480c GPS,2"Wheel Spacers, Big Daddy Tie Rod,Superior Evolution Shafts.
crawldit is offline
post #11 of 11 Old 07-15-2005, 05:31 PM
Dave Taylor
Dave Taylor's Avatar
Here is a Pic of my Jeep (5" Susp Lift, 1" Body Lift); with 33x12.5 Kumho MTs mounted: and New 35x12.5 Mickey Thompson Baja Claws sitting beside them
Here is a different angle:
Here's the measurement of the height difference:
Here is the Baja Claws shown after they were mounted (and Jeep in a rarely-seen clean state):
Nashville, TN (Franklin)
Lon. 86'54.285' W
Lat. 35'58.310' N
Alt. 610'
Dave Taylor is offline
TJ's with Rubicon Flares, 4" lift, with 33" or 35" tires HANKiE Jeep Picture Requests 12 05-08-2012 09:23 AM
Some call it "Dolores", some "Misery" mikes_muse Jeep Builds 5 10-18-2009 12:36 PM
Dark Grey WJ with black or chrome Soft 8"s 16" or 17" Jeep1384 Jeep Picture Requests 1 05-05-2009 08:05 AM
2"-2.5" suspension lift+ 1"bl with 31" tires bmboll Jeep Picture Requests 5 03-29-2006 12:28 PM
My new "Sahara Edition" Liberty...package "S"... Liberty-4-All Jeep Builds 19 06-06-2002 10:41 AM
