33x12.5 vs. 33x10.5 Front pics - JeepForum.com
post #1 of 12 Old 05-31-2008, 08:24 AM Thread Starter
tokyonavy
Interested in seeing the visual difference between 33x12.5 and 33x10.5 tires.
tokyonavy is offline
post #2 of 12 Old 05-31-2008, 08:33 AM
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
33 x 10.50
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build thread
dogbluedrummer is offline
post #3 of 12 Old 05-31-2008, 11:43 AM
Swing Fixer
Swing Fixer's Avatar
33 X12.50 - the fist pic is mounted on stock wheels, the bottom two pics are on a rim with 4" backspacing.
Swing Fixer is offline
post #4 of 12 Old 06-01-2008, 08:53 AM
otisdog
2008 WK
33 x 10.50 front Jeep. Wider on back.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #5 of 12 Old 06-01-2008, 02:01 PM
KMET
33x12.5 Stock wheels w/ wheel spacers
o6 LJ see profile...
KMET is offline
post #6 of 12 Old 06-01-2008, 02:33 PM
flatlander757
33x10.50 Swampers
size comparison in relation to myself in the white shirt:
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #7 of 12 Old 06-02-2008, 11:30 AM
dutchphantom
mine has 33'12.50/r15 mt here is the pic
http://img84.imageshack.us/img84/7195/dscf1616tc3.jpg
sorry dont seem to get the picture right so here is a link to it
what site are u using btw for hosting
Can you wait forever, if time is all it takes
dutchphantom is offline
post #8 of 12 Old 06-02-2008, 01:31 PM
skeebs
dutchphantom, Click free for you.
BTW, I use Photobucket.com. Only way I could figure to size down your pic (IT WAS GIGANTIC ) was to save as, modify it, then host myself, hope you don't mind.
tokyonavy - here's mine for your search:
33x12.50x15, 3.75" backspacing, 3" BB
Sorry, none with 33x10.50's.
skeebs is offline
post #9 of 12 Old 06-02-2008, 05:47 PM
0blcktj6
Not the best pictures but the tires are 33x12.50x15 on Pro Comp steelies with 3.75" BS.
3" Currie progressives, OME Shocks, 1" BL, 1" MML, 35x12.50" KM2's, 4.88's, Detroit in rear, Vanco BBK, Currie CA's
My Build Thread:
0blcktj6 is offline
post #10 of 12 Old 06-02-2008, 08:00 PM
Stout95YJ
33x10.50 BFG MT's
yeah I know it has squares instead of circles
Stout95YJ is offline
post #11 of 12 Old 06-02-2008, 10:39 PM
dutchphantom
@ksp2002tj thanx for the info i made an account at photobucket right away
post #12 of 12 Old 06-03-2008, 05:28 PM
97tjconan
33x12.50,s on 3.5 of lift....
97tjconan is offline
TJ 4" Lift and BFG KM2 33x12.5 & 33X10.5 barefoot352 Jeep Picture Requests 15 07-03-2010 01:29 PM
33x10.50 BFG MT's compared to 33x12.50 0blcktj6 Jeep Picture Requests 21 08-27-2008 09:31 PM
33x12.50 versus 33x10.50 WrangBlake Jeep Picture Requests 2 02-07-2007 12:20 PM
33x10.5 or 33x12.5 Drew_Jeep14 Jeep Picture Requests 32 04-29-2006 09:44 PM
33x12.50 and 33x10.50 on 4-5" afguy Jeep Picture Requests 3 11-05-2005 04:02 PM
