3.5 RE SuperFlex lift pref. with 35's or 33's would love to see them flex or just....
#1 | |
3.5 RE SuperFlex lift pref. with 33's would love to see them flex or just....
the height of the rigs wen installed
NIGHT CREW #16 Yellow Jeep Club #67 My Build Thread- http://www.jeepforum.com/forum/f22/mitchin-02-tj-sport-973277/ THANK YOU TO 97tjeff, Metalcloak!!! Last edited by Mitchin; 01-05-2009 at 02:22 AM.. |
#2 |
daily bump
NIGHT CREW #16 Yellow Jeep Club #67 My Build Thread- http://www.jeepforum.com/forum/f22/mitchin-02-tj-sport-973277/ THANK YOU TO 97tjeff, Metalcloak!!! |
#3 |
http://www.jeepforum.com/forum/f59/re-3-5-super-flex-kits-only-630586/
I had a thread about this a while ago. i also have a pic of my jeep with that kit in my profile. i cant post any pics though cuz im at work. ha ha |
#4 |
want it rite or rite now?
3.5" re on 33's...
![]() ![]() ![]() with 37's rolled up next to the 33's... ![]() 3.5" with highlines and 37's.. ![]() ![]()
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#5 |
Can you fit 35's with the 3.5 super flex lift?wanna run 35 pitbulls with that lift if possible. ![]()
#6 |
#7 |
How much lift did the 3.5" RE springs net you, over stock height?
2007 JK-X 2dr soft top, OME MD/Bilstein 5100's= 3.5" lift, 15x8" Cragar Soft 8's, 35x12.50-15 BFG KM2's. |
#8 |
#9 |
here was mine with 33's and the 3.5" RESF and i'll let you see what i have now
![]() and here with 5.5" RE LA Extreme duty ![]() ![]() this one measured out at 110.5" on the RTI ramp, if i had my rear disconected i would have done better ![]()
5.5" RE LA, 35x12.50 MT MTZ, Eagle Alloy rims, Hella Lights, RE adjustable track bars, Rhino lined, SYE kit custom driveshaft, Warn front and rear bumpers w/ tire carrier, Warn tabor 9k winch, ARB rock sliders, Tru-trac, 4.11's, ARB Snorkel. http://www.jvillejeepers.com/ Last edited by becker21603; 12-27-2008 at 11:54 PM.. |
#10 |
3.5 RESF & 33x12.5.15........Works ok.
L1 |
#11 |
wow
wow Loser1 that is amzing flex what else have you done to that jeep please enlighten me!
#12 |
Most kits will measure out around 4.5 when first installed. I really like the kit it will do just as it says.. flex. First pic is Rausch Creek. Second is Pa jeeps RTI ramp. It ramped 910, would have gotten more but the shocks were maxxed.
#13 |
#14 |
The ramp was very constricting. i wasnt fully flexed but it looks cool all the same. |
#15 | |
if i was to put the 3.5" sf on with a 2" body lift and stay rollin 35s... how would this look? any pictures or would it look funny?
2000 TJ sport "STORMTROOPER" dual tops, 4.0L, 2.5" coil spacer, 2" BL, jks quicker disconnects, worn out 35x12.50 bfg M/Ts, 15x8 d window rock crawlers w/ 4" backspacing, front stinger, custom rear bumper, superwinch lp8500 winch, a to z rocker guards, husky liner floor mats, CB/PA system, daylighters, and straight exhaust My custom stinger build Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
