265/70/17 on a non-lifted WK - JeepForum.com
post #1 of 4 Old 09-25-2009, 03:35 PM Thread Starter
jd1969
Anyone have a pic of this? Will they fit on a stock height 2005 GC?
jd1969 is offline
post #2 of 4 Old 09-25-2009, 08:51 PM Thread Starter
jd1969
Sorry for the newb question, I found out the answer for myself.
jd1969 is offline
post #3 of 4 Old 10-09-2009, 10:07 PM
micajustin
1970 CJ5
265/70 R17 on Non-Lifted WK Grand Cherokee 2005-2009
I am assuming a 2" lift is required for these tires, I would like to know if anyone has tried it. I want to know the widest tire I can fit without lift. Sounds like I will have to lift it 2" though.
micajustin is offline
post #4 of 4 Old 02-04-2013, 09:19 PM
micajustin
1970 CJ5
I got a set of Rubicon rims and tires, 265/70R17, from a 2009 Wrangler. I used spacers in the front for a while, then I just ground off a little metal from the front brake calipers and the spacers are no longer needed. There is just a very small amount of rubbing when you turn the wheel all the way, but it is not even noticable until you look at the plastic in the wheelwell. It has not even wore through the plastic yet, and I have 82,000 miles on them. Again, this is with no lift.
lifted YJs on 35s or 37s TMC23 Jeep Picture Requests 29 09-27-2012 01:24 PM
Got a lifted WJ? dckaz Jeep Picture Requests 3 10-05-2009 09:26 PM
My Lifted LJ crazylj Jeep Builds 4 01-16-2007 09:14 AM
Lifted WKs Lan1201 Jeep Picture Requests 0 12-09-2006 09:44 PM
my TJ lifted wakeboarder 21 Jeep Builds 3 06-14-2004 01:43 AM
