2" Suspension lift with 32's - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > 2" Suspension lift with 32's
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 03-18-2007, 05:30 PM   #1
twinjeep97
anyone have a 2" suspension lift with 32's??? also could i keep my stock rims if i went up to 32's?
Green 97' TJ Wrangler. 32x11.5 Dunlop Mud Rovers. 2 KC Daylighters/Smile Covers. 2 Hella Off-road Fog lights. Stainless Taillight guards. Smittybilt Rock Crawler SRC front Bumper, 2 Silver WARN Towhooks.
*New* 2" BDS Suspension Lift
twinjeep97 is offline   Reply With Quote Quick reply to this message
Unread 03-18-2007, 07:52 PM   #2
GreenJip
Here are some old pics for you. It technically has 3" lift, 2" BB plus 1" BL. The tires are 32x11.50xR15 on the stock rims. I had to use wheels adaptars to get the backspacing right. If you need some more info on this set up, tool around www.4x4xplor. He has some good write ups on this mod.
GreenJip is offline   Reply With Quote Quick reply to this message
Unread 03-18-2007, 08:36 PM   #3
dm70
Check out this thread..http://www.jeepforum.com/forum/f59/all-jeeps-32s-313163/
You can keep your stock rims but some people report that they rub on the rear spring near the top, they don't on mine. They will rub the lower control arms at full lock but you can add a washer or two on the stearing stops. It cuts down on your turning radius a little bit though. Hope this helps.
dm70 is offline   Reply With Quote Quick reply to this message
Unread 03-18-2007, 09:26 PM   #4
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
2" budget boost on 32" maxxis bighorns. nothing more nothing less than what you asked for:
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 03-18-2007, 10:16 PM   #5
bsruther
2" pro comp lift. Kumho 834 MT, 32"
bsruther is offline   Reply With Quote Quick reply to this message
Unread 03-19-2007, 08:38 PM   #6
nicolas-eric
2" BB and 32x11.5x15on 7.5x15 wheels.
for the street it was ok. but off the road and disco'd there was tire rubbing everywhere.
click me
now with 2" BB and 2" BL there is no more rubbing:
click me
4" OME & 1" Spacer & LT Shocks 2" BL 1" MML JKS Discos JKS Rear Links OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 ARB Airlockers ARB Diff Covers 4.56 Gears SS Brake Lines
Warn Skids Genright Rock Slider Smittybilt Rock Crawler Rear Bumper Safari Snorkel OBA
12.000 lbs Winch Synthetic Winch Line 4x 130W Hellas 4x 200W Hellas @ Lightbar E-Fan
Jeep TJ Runicon Pics www.timbercrawler.de
nicolas-eric is offline   Reply With Quote Quick reply to this message
Unread 03-19-2007, 09:24 PM   #7
Rick98TJ
1997 XJ Cherokee
I'm not sure what the exact amount of lift is but it's on 32's. The specs are in my sig
[/QUOTE]
[FONT="Franklin Gothic Medium"][COLOR="Red"][SIZE="4"][B]RJC #380[/B][/SIZE][/COLOR][/FONT]
98 TJ Sport
CV/ZJ/JK Frankenlift:
ZJ front coils w/ 2" Daystar spacer
JK Shocks front and rear
CV Rear coils
Rick98TJ is offline   Reply With Quote Quick reply to this message
Unread 03-19-2007, 10:51 PM   #8
SecondTJ
SecondTJ's Avatar
You could keep the stock rims, but with a 11.5" wide tire you will need wheel spacers.
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 9k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE
SecondTJ is offline   Reply With Quote Quick reply to this message
Unread 03-20-2007, 08:49 AM   #9
Mr. Tarmac
I just installed 1.25" Spidertrax spacers with my stock Ravine wheels. They are awesome. Seems to actually roll a little smoother.
Mr. Tarmac is offline   Reply With Quote Quick reply to this message
