2" Budget Boost on 33's - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Picture Requests > 2" Budget Boost on 33's
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 04-05-2009, 05:03 PM   #1
ZJeepMI
My father is upgrading to 33's on his TJ and right now he is running a 1.75" Lift (spacers), he will eventually put a 1.25" body lift on it but we are curious what it is going to look like until then.
Also, would it be a bad a idea to disconnect the sway bar offroad with this little room? Or will it be OK?
Thanks.
2001 TJ Wrangler, 2.5l, 5 speed, Stock.
Previous Jeeps:
'98 XJ, 3.5" lift, 31" BFG A/T, Aussie Locked D30 with Alloy Shafts, 8.25 rear, SYE, Skids, JCR Front bumper, Roof Rack
1995 Jeep Grand Cherokee, 2" lift, 31's, V8, NP242...
1993 Jeep Grand Cherokee, Stock, 230K miles.
ZJeepMI is offline   Reply With Quote Quick reply to this message
Unread 04-05-2009, 05:28 PM   #2
gus54
To give you an idea - I have a 2" spring lift - no body lift - and 32s. Here's a pic with the sway bar discoed.
[IMG][/IMG]
You could add to the bump stop length to reduce flex, but that kind of defeats the purpose. I will be adding a BL before I disco off road.
gus54 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2009, 05:55 PM   #3
OzarkOutdoors
It'll fit but any bump bigger than curb will probably rub your fenders and disconnecting will probably remove them.
Mine before the BL and the spacers measured 2 1/4 inches.
2008 Black JK Sahara Unlimited-Current Vehicle
325/70/17 Falken Wild Peak AT XD Addicts
2.5 inch BB, 1.25 RC Body Lift, Dual Top
s
OzarkOutdoors is offline   Reply With Quote Quick reply to this message
Unread 04-05-2009, 08:15 PM   #4
ZJeepMI
Thanks guys, we are still not sure what we are going to do yet. He wants the 33's, but he can't afford a real lift, looks like we will have to get the BL on quick.
Any more?
Previous Jeeps:
Unread 04-05-2009, 08:48 PM   #5
JeepnTXJ
'83 CJ7. 258, T5, D300. D30, M20 1 pc. shafts
4" Skyjacker, 33x12.5.15 Nokian Vatiiva on wagon wheels.
JeepnTXJ is offline   Reply With Quote Quick reply to this message
Unread 04-05-2009, 09:03 PM   #6
OzarkOutdoors
Don't sweat the BL, did it by myself one evening after work..2 1/2 hours. The RC was a good price, $120 on their website but they matched their eBay prices of $99.
Ordered it at lunch on Monday, had it by Wednesday, installed it on Thursday.
s
Unread 04-05-2009, 10:30 PM   #7
kylerobichaud
97 TJ- 2" and 33's and a whopping whole 4 cylinders
kylerobichaud is offline   Reply With Quote Quick reply to this message
Unread 04-06-2009, 09:57 AM   #8
tnjeep03
x2 on the 1.25" BL. The JKS BL+MML will only set you back ~$150 and with your spacer lift will be perfect for 33s. Install is straight forward.
I have the 2" RE BB (which everyone says is slightly smaller than 2") and the 1.25" JKS BL/MML running 33x12.5 KM2s on mine. If you disconnect you will rub slightly on the flare NOT the fender.
Kinda depends on your long term plans if this is the right option for 33s, but my jeep came with the spacer lift, so it was an easy choice for me.
tnjeep03 is offline   Reply With Quote Quick reply to this message
