Okay so this was our staging area. One of the wheelers friends next door to the trails
So because I was all mad I didnt think to get pictures . But my XJ was just NOT running right at all. Died on me driving, had no power, was like UGH was a ****ty start. Then once we hit dirt I overheated. Turns out after I did the water pump I didnt properly burp the system and I didnt have enough water in it. After figuring it out and a small stop we were on our way again.
So now we are stopped again. Jeff in the trooper didnt air down and first and then decided to air down. Meanwhile the 4runner had loose valvecover bolts and was loosing some oil!
So onto some wheeling I was the first stuck of the day. Dropped my diff right onto a dirty rock mound. Could not pull off of it so I opted to get a tow back
Quick look at the guys im holding up lol
Here is the first real stuck of the day
Unpictured is the rock his front axle was on and he was totally stuck.
He was the first winch of the day
Get him out and he is stuck again
Then a little farther and wedges his pass front tire between two rocks and gets another winch :highfive:
He backs out and goes around and here is a picture of the TJ starting into the spot where the XJ got stuck. You can see how perfectly the rocks are to get stuck on both ends
This is the rest of the way down the trail with a really large drop
Video of the TJ doing it
So after that we hit some main road and then found another trail.
Heading to this step up log to a small mud pond
I think this was after I just got up the step up
