Quantcast Most fun you can have with clothes on! - JeepForum.com
Go Back JeepForum.com > Four Wheeling Forums > Trail Reports & Pictures > Most fun you can have with clothes on!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 04-01-2007, 04:21 PM   #1
dogbluedrummer
Trust me....
dogbluedrummer's Avatar
I am no longer a wheelin' virgin! We just got back from running some oversized ATV trais. I never thought a jeep could make it up the first set of hills. I don't know the grade, but I could not see the first 50 feet of trail when going up. The TJ was very nimble as we worked our way thorugh the sharp turns between trees. The trail was not wide enough for both mirrors - however I am now one step closer to getting mirror relocation brackets.
We came across some big, long ruts which we did without tooo much of a problem, just a lot of sliding as it was muddy. Thankfully, the smaller pine trees serve as good stopping points. They give a lot when hit and don't leave marks!
The highlight was my friend going into (not through) a huge mud puddle. He had a stock Cherokee and lost all traction about halfway through. BREAK OUT THE RECOVERY STRAP. So his hitch was the highest point, and still below water. He had 3" of water in his floorboards.....and a lot of mud.
From there we ran a creek bed for about a mile, crossing numerous ruts and mud puddles before climbing back out. No damage - except the smell he will get in a few days as his Jeep dries in the sun!!
Lessons I read in JeepForum and now KNOW:
ALWAYS take a friend, never go alone. (Thank you Forum)
Buy a 2"x30' RECOVERY strap, NOT A TOW STRAP WITH HOOKS (Thank you Forum)
Take a shovel (mounted under hood, Thank you Forum)
Match your tires to your wheeling. I need MTs, not ATs for my area (Thak you Forum).
Figure out how to get into 4Low BEFORE you're halfway up the hill!!! Rookie
Make sure you have a rear tow hook.
Take a rough-cut bow saw (like what you use to cut down Christmas trees)
Take a trash bag and haul OUT more than you haul IN.
Anybody have a recommendation for an entry-level winch?
Are BFG MTs better than Pro Comp MTs? 80% DD, 20% trails/mud
There's probably a million more lessons, but hey, it was our first day!
Here's the best part - I forgot the camera. ********** So, no pics.
Patriot Blue 2001 TJ
Everything I need to fix on the heep: ABS indicator, speed 4 on the blower fan, torn softop over driver's head, both seat release/tilt cables, missing center cap on spare, broken under hood light, wire up the CB, wiring problem with the reverse lights, broken bottle jack, leaky front and rear pinion seals, loose trackbar relocation bracket, torn drivers seat on the side, broken center console lock, lost nuts for door hinges, squeaking centering ball, loose parking brake cable, oil change and rotate the tires.
My build threadhttp://www.jeepforum.com/forum/f22/free-wife-good-home-pics-included-528892/
dogbluedrummer is offline   Reply With Quote
Old 04-01-2007, 04:23 PM   #2
Chris @ GATR
I bet this doesn't stay long in the tech section.
Got ignorance? Please see below.
[QUOTE=kd4yor;4763909]Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).[/QUOTE]
Chris @ GATR is offline   Reply With Quote
Old 04-01-2007, 04:37 PM   #3
dogbluedrummer
Trust me....
[QUOTE=dogbluedrummer]
Sorry, for those of you who like the tech questions blatently obvious............
My build threadhttp://www.jeepforum.com/forum/showthread.php?t=528892
Old 04-01-2007, 05:33 PM   #4
bigchevyman24
I've got the harbor freight 8k lb winch made by Chicago Electric...it was only $264 when I bought it a couple months ago with a 20% off coupon I found on the internet. Bought a year warranty for an extra $30 so it's good for a year for $300 and it came with a universal mounting plate that works with just a few new holes drilled for the TJ bumper. I would say that if you are not gonna use the winch alot, and it's more for a security blanket(it does work well, however) go for it...it saves you at least $200+ and it is a great winch in my opinion...a little slow, but if you're stuck anyway, you're not going anywhere fast...you can do a search for harbor freight winch and get lots of info on it...I believe it is a great bang for the buck and a great entry-level winch!!! My .02
2000 WJ - I6, Auto, 2WD 2" BB, 18" JK wheels/32" tires, Converting to 4wd
---2WD TO 4WD CONVERSION---
97 TJ 4" lift, 35" boggers, lockright front D30, 9k winch - SOLD
95 XJ 33" TSL's, 2" BB, SEVERE trimming - SOLD
2003 WJ LIMITED PART OUT!!!!!!!!!
bigchevyman24 is offline   Reply With Quote
Glock Forum
