Jeeps Going Wild @ The Badlands: Sept. 24, 2011 - JeepForum.com
post #1 of 52 Old 09-25-2011, 11:03 AM Thread Starter
Jeffro06
Jeffro06's Avatar
On Saturday September 24, 2011 a few of us headed out to the The Badlands Off Road Park in Attica Indiana. This would be only my third trip down this year, which is fewer than past years.
This trip down my 10-year old daughter, Ashlynn, rode along. We hit the rode at about 5am. The weather forecast was 60's and a 50% chance of rain. The day started in the 40's and cloudy. On the way down we did hit some rain, but it was gone long before we hit Attica.
We arrived in the park @ 0920 hours (add an hour for Indy time) and met up with ksilovich, 5cents and Dozer.
Me
ksilovich
L: 5cents R: Dozer
Ashlynn grabbed a few shots to start the day.
After airing down, flagging up, and removing other various parts we headed into the woods. 5cents had informed me the park had made some changes and dynamite had been used since my last visit, so he took the lead for the day.
Following Dozer into the woods.
We weaved our way through the woods for a bit, then 5cents mentioned a little climb that included a railroad tie.
It's steeper than it looks.
Dozer hits the railroad tie climb....he's open/open.
The ground was a bit wet so traction wasn't exactly prime.
Dozer finally prevailed.
5cents was next.
Traction was still the issue....lockerless.
Ashlynn grabbed a shot of me walking right up....locked f/r.
Ksilovich walked right up. 37s, ARB rear, open front.
After the railroad tie we continued winding our way through the woods, around the trees, and over the hills.....to grandmothers house we went.
I honestly had no idea where we were for most of the morning.
Random shot along the trail.
We managed to make our way to Red Trail, where ksilovich did this:
My new dSLR has HD video and that's the first time I used it on the trail. I like it.
Dozer made his way around this rock on Red.
ksilovich took a more direct route.
What you can't see, but probably will when other's post up is me getting stuck after taking the above shots. I hopped back in the jeep and started pulling forward, almost instantly my front end took a hard right and I slid down a hill and came to an abrupt stop. I felt like I was leaning to the passenger side....alot. It felt worse than it looked...which is usually the case. There were a few trees on the passenger side and I really didn't want to hit them.
It was quickly learned that I had a tree blocking the front axle, so we tried to tug it backwards. I hooked to ksilovich and he gave a tug....nothing. Time for the winch. I hooked to a tree (using a tree saver of course) and pulled myself up and over the tree. So when you ask "what should I buy first?"....don't hesitate to get the winch. This would have been a booger of a situation to get out of without the winch.
Once free we set our sites on a big rock, next to a big tree. The tree had all kinds of battle scars on it.
This sure looks like the tree wins, more times than not.
First up, 5cents:
There was a fine line between making it, getting hung up on the rock, or hitting the tree.
Last edited by Jeffro06; 09-25-2011 at 07:53 PM. Reason: Said 38's, when it's really 37's....I am soooo sorry.
Jeffro06 is offline
post #2 of 52 Old 09-25-2011, 11:04 AM Thread Starter
Jeffro06
Jeffro06's Avatar
Working hard not to hit the tree.
5cents bumped the tree, but we pushed the jeep off the tree and he was through.
Made it!
I went next, having lockers made it easier, but the tree still scared the crap out of me. I managed not to touch it.
ksilovich was up next. His extra height made him worry a bit more about the tree. We assured him that his taller tires and extra ground clearance would allow him to go over more of the rock, thus clearing the tree......nice theory.
Things got a bit tippy.
Right about here I decided to run, and save myself.
He didn't tip over, but he did bounce off the tree, putting a small hole in the rear corner of the top....nothing a needle and thread (nylon thread) can't fix. We hooked a tow strap to the front bumper and pulled to help bring his tires back to earth, and he made through without further drama.
Another group of guys showed up and one of them decided to climb the v-notch in the wall:
"You broke a leaf."
A broken leaf didn't stop him from making it up.
Or going back down.
After Red we cut through the quarry.
Ksilovich did the step....a slippery step.
We made our way along the rim trail, through woods, and down the creek. Things sure looked different to me. The creek's path had been changed in one area. It use to have a s-turn, but had decided it wan't to go straight I guess.
We traveled beyond the tubes, then climbed our way out.
Dozer had to give it "more power" to make it.
He hit the easy button.
As we made our way to the "dunes" 5cents thought we should take a steep slippery exit.....
...Thought.
With the wet slippery clay getting the best of 5cents we decided to opt for an easier exit. Once in the dunes I let Ashlynn drive. She was so happy. She climbed a few small hills, and once home rubbed it in her twin sister's face.
One happy kid.
We continued to wind our way through the woods for a bit, then headed to lunch. After lunch we traveled back to the tubes and dropped into the creek.
Random trail shot of Dozer.
We kind of did a loop in the creek, going past "the rock" but returning to climb it.
Making our way back to the quarry, near Purgatory.
Jeffro06 is offline
post #3 of 52 Old 09-25-2011, 11:30 AM Thread Starter
Jeffro06
Jeffro06's Avatar
Once back at the quarry 5cents wanted to give a new line a try.
Getting hung up on the cement was the biggest concern really.
He drove up the embankment on the passenger side, in an attempt to keep the rear drivers control arm from getting hung up on the concrete, but the jeep kept sliding back down to the cement.
With some great spotting 5cents was able to defeat the concrete and make it up. The control concerns were for naught. Sorry about the blurry shot, but as the jeep shifted towards me, I moved!
ksilovich had a little easier time of it.
It was now 14:30 hours and Ashlynn was ready to go home. I would have loved to stay a longer, but I knew bringing the little one along would require me to leave when she was ready. I said good-bye to everyone and headed to the gift shop. It always costs me more when I take one of the girls.
I made it home safe and sound and as near as I can tell without any damage. There were a few times during the day that I heard a few noises that made me pucker a bit, but that's a part of the game I guess.
I do hate the drive to and from the Badlands, but it was worth it in the end.
Hopefully I don't go so long between wheeling trips as I did this time....next time it may have to be The Cliff's
The rest of my photos.
Now.....it's time for 5cents, ksilovich and Dozer to post some pics and vids of me.
I also want to thank 5cents for leading us on some nice trails. I did a few things that I had never seen before. New is good.
PS....Ashlynn fell asleep about 10-minutes after I pulled out of the park, so I guess it really was time to go.
Jeffro06 is offline
post #4 of 52 Old 09-25-2011, 02:11 PM
99TJSahara
Looks like a good time, I can't wait to go to the badlands again.
-Joey
04 Grand Cherokee Overland
-sold
99TJSahara is offline
post #5 of 52 Old 09-25-2011, 03:50 PM
2006_Sport
I hate you
Thank god there's a small offroad park opening 50 minutes from me so I can finally get off the road. Looks like a really fun time man.
2006_Sport is offline
post #6 of 52 Old 09-25-2011, 05:11 PM Thread Starter
Jeffro06
Jeffro06's Avatar
Originally Posted by 99TJSahara View Post
Looks like a good time...
It was a fun, and it'll be even more fun to see some more pics, guys....
Jeffro06 is offline
post #7 of 52 Old 09-25-2011, 05:15 PM
5cents
My pics
5cents is offline
post #8 of 52 Old 09-25-2011, 05:16 PM
5cents
5cents is offline
post #9 of 52 Old 09-25-2011, 05:17 PM
5cents
5cents is offline
post #10 of 52 Old 09-25-2011, 05:40 PM Thread Starter
Jeffro06
Jeffro06's Avatar
I see you did Orange after I left.....makes me sad that I wasn't there.
Any pics/vids from Red?
Jeffro06 is offline
post #11 of 52 Old 09-25-2011, 05:44 PM
5cents
I was having some technical difficulties. Moving over to picasaweb from photobucket. Slight learning curve to the settings. Think I got it hammered out. Working on uploading videos to youtube.
5cents is offline
post #12 of 52 Old 09-25-2011, 05:47 PM Thread Starter
Jeffro06
Jeffro06's Avatar
10-4. I thought you'd have some vids.
Jeffro06 is offline
post #13 of 52 Old 09-25-2011, 06:42 PM
5cents
5cents is offline
post #14 of 52 Old 09-25-2011, 06:43 PM
5cents
5cents is offline
post #15 of 52 Old 09-25-2011, 06:44 PM
5cents
5cents is offline
Jeeps gone wild badlands jan. 3 mascun Trail Reports & Pictures 44 01-23-2010 01:03 AM
Jeeps Gone Wild - Badlands 8-15-09 TheEddie Trail Reports & Pictures 17 08-25-2009 06:05 PM
Jeeps Gone Wild Dec. 6th Toys for Tots @ Badlands TheEddie Trail Reports & Pictures 40 01-29-2009 08:01 PM
Jeeps Gone Wild Badlands 9/14 aka Hurricane Ike Run gribbles Trail Reports & Pictures 28 09-21-2008 12:51 AM
Badlands, Jeeps Gone Wild event, May 17th, 2008. Jeffro06 Trail Reports & Pictures 27 05-22-2008 09:30 PM
