Won't stay running when engine warms up. - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Won't stay running when engine warms up.
USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 04-03-2011, 02:35 PM   #1
ckritcoad
77 Waggy
401 AMC
MSD Ignition Box
Mallory Unilite Dist. & Coil
Edelbrock carb (not sure cfm)
I bought the Jeep a year ago. It ran but pretty week for a long time. All of a sudden it stopped running after the engine warmed up. I realized the orignal owner had removed and bypassed the original ignition box. I put an MSD unit on it and it fired up no problem and ran like a horse. However, I still have the same issue...when it warms up it will die in the middle of driving it and it won't restart. Any ideas?
Thanks in advance.
ckritcoad is offline   Reply With Quote Quick reply to this message
Unread 04-03-2011, 08:18 PM   #2
pleontks
1976 J-Series Truck
Choke.
Mine's a 76 360 with the MSD, jeep elec dist, quadrajet
In an ideal world, I would run the vacuum choke, but I'm not smart enough to figure out all that extra stuff. I've tried the elec choke, not a fan. Now I just run manual chokes on everything. Pull it in to start, push it in when warmed up.
You can get a manual choke kit from kragen/checkers/shucks for around $10
Beauty is in the eye of the jeepowner.
pleontks is offline   Reply With Quote Quick reply to this message
Unread 04-05-2011, 03:55 AM   #3
cheese_man
1977 CJ7
check the ignition coil ballast resistor
it could be corroded and heating up then stop passing electrical current through it
you can buy a mallory electronic part for that dist and remove the ballast resistor all together
cheese_man is offline   Reply With Quote Quick reply to this message
Unread 04-05-2011, 09:33 AM   #4
pleontks
1976 J-Series Truck
with the MSD ignition box and coil, you should NOT be running a resistor. (either a resistance wire or a ballast resistor). You should have 12v at the coil.
When I had my prestolite ignition, she would run great, but wouldn't start if she was warm.
Unread 04-05-2011, 10:46 AM   #5
davsfsj3xjs
1987 FSJ Wagoneer
My '87 GW used to do that until I rebuilt the carburetor. I believe the the accelerator pump was at fault, I may be wrong, but it ran great afterwards.
4x4s are what you make of them, or do with them. No guts - No glory ;')
davsfsj3xjs is offline   Reply With Quote Quick reply to this message
