wont start. to hot? - JeepForum.com
post #1 of 6 Old 07-26-2012, 02:31 PM Thread Starter
mkavanaugh6
1989 FSJ Wagoneer
wont start. to hot?
so i just replaced the starter in my jeep. it now turns over but wont start. it wouldnt turn over before so i feel im on right track. any advice? i did read that on my 89 grand wagoneer wont start when its hot. and its easily 100 out right now. so i will def try after it cools down again. it ran fine then wouldnt start. it has sat in heat for two weeks without running. couldt get it done right away.
mkavanaugh6 is offline
post #2 of 6 Old 07-26-2012, 02:45 PM
pleontks
1976 J-Series Truck
do you have fuel at the carb? In two weeks, the gas probably would drain back to the tank. Do you have gas in the tank? Two weeks in the heat would make a lot of it evaporate. My buddy just had this problem on his camaro when he replaced the distributor. I came over to time it for him cause it wouldn't start. It didn't have any gas.
After checking for gas, check for spark, then let us know where you're at.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #3 of 6 Old 07-26-2012, 02:56 PM Thread Starter
mkavanaugh6
1989 FSJ Wagoneer
thanks. ill check today. i need my baby back. im new to some of this or im learning as i go. and i hope this doesnt make me sound dumb but fuel in the carb? is that like after u pump the gas? like getting in lines and what not or is there somen i need to do extra?
post #4 of 6 Old 07-26-2012, 03:17 PM
CSP
Any vehicle, if operating correctly, shouldn't have trouble starting in weather with temps much hotter than 100.
Three things are needed for the engine to run, fuel, air, and spark. The web is full of information on how to check for all three and air is pretty much a given that you don't have to test.
CSP is offline
post #5 of 6 Old 07-26-2012, 07:15 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
its possible you just need to crank it for a while, as stated the carb can either evaporate or boil off or drain the fuel back out.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #6 of 6 Old 07-31-2012, 11:48 AM Thread Starter
mkavanaugh6
1989 FSJ Wagoneer
ok i went back out that evening when it cooled and it started for me. def was heat. from everything ive read just seems to be an a problem with that generation of grand wagoneers. well ive be driving my baby since. i would appreciate advice on my next step. im not loaded or experienced but if it can be done by me i want to do it. everything i have done so far ive learned or u fine people on here helped me.
heat , jeep , problem , starter , wagoneer
J10 wont start 240impala Full Size Jeep Forum 16 11-23-2011 09:16 AM
1987 Wagoneer runs hot wont start sbarrese33 Full Size Jeep Forum 10 09-09-2011 01:51 PM
help it wont start jeepnumber2 Full Size Jeep Forum 4 06-26-2010 09:19 AM
New motor keeps backfiring and wont start cmschule Full Size Jeep Forum 9 08-27-2009 11:40 AM
1988 Jeep wont start jeepster60 Full Size Jeep Forum 8 04-30-2009 11:59 AM
