Won't stay running when engine warms up. - JeepForum.com
post #1 of 5 Old 04-03-2011, 03:35 PM Thread Starter
ckritcoad
77 Waggy
401 AMC
MSD Ignition Box
Mallory Unilite Dist. & Coil
Edelbrock carb (not sure cfm)
I bought the Jeep a year ago. It ran but pretty week for a long time. All of a sudden it stopped running after the engine warmed up. I realized the orignal owner had removed and bypassed the original ignition box. I put an MSD unit on it and it fired up no problem and ran like a horse. However, I still have the same issue...when it warms up it will die in the middle of driving it and it won't restart. Any ideas?
Thanks in advance.
ckritcoad is offline
post #2 of 5 Old 04-03-2011, 09:18 PM
pleontks
1976 J-Series Truck
Choke.
Mine's a 76 360 with the MSD, jeep elec dist, quadrajet
In an ideal world, I would run the vacuum choke, but I'm not smart enough to figure out all that extra stuff. I've tried the elec choke, not a fan. Now I just run manual chokes on everything. Pull it in to start, push it in when warmed up.
You can get a manual choke kit from kragen/checkers/shucks for around $10
Beauty is in the eye of the jeepowner.
pleontks is offline
post #3 of 5 Old 04-05-2011, 04:55 AM
cheese_man
1977 CJ7
check the ignition coil ballast resistor
it could be corroded and heating up then stop passing electrical current through it
you can buy a mallory electronic part for that dist and remove the ballast resistor all together
cheese_man is offline
post #4 of 5 Old 04-05-2011, 10:33 AM
pleontks
1976 J-Series Truck
with the MSD ignition box and coil, you should NOT be running a resistor. (either a resistance wire or a ballast resistor). You should have 12v at the coil.
When I had my prestolite ignition, she would run great, but wouldn't start if she was warm.
pleontks is offline
post #5 of 5 Old 04-05-2011, 11:46 AM
davsfsj3xjs
1987 FSJ Wagoneer
My '87 GW used to do that until I rebuilt the carburetor. I believe the the accelerator pump was at fault, I may be wrong, but it ran great afterwards.
4x4s are what you make of them, or do with them. No guts - No glory ;')
davsfsj3xjs is offline
2.8 warms up then dies and won't start until totally cool? Calvin88 Full Size Jeep Forum 3 08-26-2009 11:04 AM
304 doesn't want to start when engine warms up dragonflyspine Full Size Jeep Forum 3 07-02-2009 05:20 AM
New to the forum and my woody won't stay running chatas1 Full Size Jeep Forum 4 03-04-2009 07:36 AM
88 GW Interior lights stay on. Kspencer Full Size Jeep Forum 1 02-03-2008 03:52 PM
1988 GW Engine Keeps Running... jnc123ny Full Size Jeep Forum 2 12-25-2007 10:36 AM
