wipers do not work Jeep Wagoneer 1988 limited. Fuse? Short? Wiring? - JeepForum.com
post #1 of 5 Old 07-18-2004, 12:41 PM Thread Starter
miler209
My 1988 Jeep Wagoneer Limited wipers do not work. The washer works though and everything else on the column.
miler209 is offline
post #2 of 5 Old 07-21-2004, 09:35 PM
JustinGJ
JustinGJ's Avatar
1990
I'm guessing you're in the wrong area, try the Cherokee forum. If your Jeep looks like the one over there
then it's an XJ, same as a Cherokee and to a lesser extent, the Comanche MJ.
1990 Wagoneer XJ
4.5" Rough Country full spring pack lift
Rubicon Express trackbar
Custom grille guard
JustinGJ is offline
post #3 of 5 Old 07-22-2004, 10:51 AM
oldschool8604
why would he have to go to the cherokee forum when he said his WAGONEER LIMITED wipers dont work?
Try changing the fuse, theyre quite cheap, then use a wire tester to check the wiring and such.
Also see if they are seized wth rust, that might have happened
89' Wagoneer Limited - The ShaGGiN' WaGGiN'
Blue Jeep Club Member #86
http://www.cardomain.com/id/oldschool8604
oldschool8604 is offline
post #4 of 5 Old 07-22-2004, 06:14 PM
JustinGJ
JustinGJ's Avatar
1990
Because our Wagoneer Limited XJs have a lot more in common with the Cherokees that they're identical to, instead of the full size Grand Wagoneers that we only share a name with. I just figure I'd lead him towards the XJ section.
Try leaving the switch on and grabbing the wipers, gently pull them up to see if the motor is just stuck.
1990 Wagoneer XJ
Custom grille guard
JustinGJ is offline
post #5 of 5 Old 07-23-2004, 08:48 PM
oldschool8604
well ya, of course its closer to a cherokee, way closer...its hardly similar to the grand wagoneer or grand cherokee...i mean somethings are similar, but these are closer to cherokees, its just a chero with some wood paneling
Gw 1988 - Where Is The Fuse Box ? 2012carlo Full Size Jeep Forum 2 11-05-2008 02:49 AM
1988 Jeep Grand Wagoneer Restarting Problems banderson98271 Full Size Jeep Forum 2 04-30-2008 11:59 AM
Restoring A 1988 Jeep Wagoneer CSprinkJR Full Size Jeep Forum 6 12-25-2007 06:00 PM
1988 Jeep Grand wagoneer run-on surfdad Full Size Jeep Forum 2 08-11-2006 02:10 PM
1988 Grand Wagoneer RBlatch Full Size Jeep Forum 1 02-28-2005 09:57 AM
