width - JeepForum.com
post #1 of 10 Old 08-20-2002, 06:27 PM Thread Starter
blackjeep
width
I know this isnt the appropriate forum and i know i keep asking questions about this subject, but i cant find a solid answer as to what years the wagoneers were wide tracks and what years they were narrow tracks. I believe the wide tracks are 62.5 inches wide, right? Oh yea im refering to the front dana 44. Thanks for any info.
blackjeep is offline
post #2 of 10 Old 08-20-2002, 06:47 PM
RCHavok797
RCHavok797's Avatar
Please post this in the Wagoneer forum or atleast the General Discussion Forum.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #3 of 10 Old 08-21-2002, 07:33 AM
RodeoRob
RodeoRob's Avatar
Well you've opened a can of worms here. At one time there was a really good/long thread on POR discussing/debating this.
Basically, what i've gathered and seen first hand... there is *no* wide track/narrow track wagoneer. *all* wagoneers have the same width axles (front being about 62.5"). wide/narrow track only applies to FSJ Cherokees.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #4 of 10 Old 08-21-2002, 07:57 PM
CSP
Yep, Wagoneers/Grand Wagoneers were all narrow track. Full size Cherokees could be either wide or narrow.
CSP is offline
post #5 of 10 Old 08-21-2002, 10:38 PM
Kev
Master of the Obvious
Kev's Avatar
This is from the YJ Faq found at BC4x4.com:
Wagoneer Axles
The best axles to swap into your YJ are found under a 86-91 Jeep
Grand Wagoneer. These are driver side on the front. Dana44 front and
rear 30 spline with front disc brakes.
The width is around 62" flange-to-flange. This is within 1.5" of
a stock D30/35.
The only thing you will likely need to do is get lower gears for them
as the Waggoneers were setup for highway gears (they were the Jeep
luxo wagons of their day).
- Chris Olson
HTH
"AN ARMED SOCIETY IS A POLITE SOCIETY"
"We, too, born to freedom, and believing in freedom, are willing to fight to maintain freedom. We and all others who believe as deeply as we do, would rather die on our feet than live on our knees." FDR
Blue Jeep Club Member #4
92 Canyon Blue Wrangler YJ 4.0L - with some fun goodies
Kev is offline
post #6 of 10 Old 08-22-2002, 10:18 AM
TJx2
AXLES
Front Axles
Model Year Availability Notes
D-27A 1962-70 Wagoneer
D-30 1971-73 Wagoneer
D-44 1962-88 All J-Trucks, 1974-92 Wagoneer/Cherokee/Grand Wagoneer
D-44 w/vacuum 1983-84 All except J-20 With Type 1 NP 229 or NP 228 transfer case disconnect
Rear Axles
D-44 1962-79 All except X,Y,Z series trucks and J-20
1986-92 All except J-20 From late 1986
D-53 1962-68 X,Y series trucks only Semi-floating axle
D-60-2 1969-73 Trucks only Semi-floating axle
D-60 1969-88 Z series trucks Full-floating axle J-20 only
D-70 1962-68 Z series trucks only Full-floating axle
AMC 20 1980-86 All except J-20 Through early 1986
Only Wide tracks were Cherokees (I have a '78) and I think years 1977 to 1986 roughly. It was an option... Cherokees were also narrow track.
The wide tracks wouldn't work on your YJ anyways.... at least on my '78 it is a front passenger side drop on the front, and a slightly passenger side offset rear. When I got it I thought at worst I could drop the axles into my TJ. Whoops. If you had a CJ you would be in luck... there are even standard kits that require very little welding to mate wide tracks to the CJ.
Try www.ifsja.org. Awesome FSJ info.
TJx2 is offline
post #7 of 10 Old 08-22-2002, 01:32 PM
CSP
Any fullsize Jeep that is 1980 and newer is driver side drop. They are perfect for a YJ and doable on a TJ.
CSP is offline
post #8 of 10 Old 08-22-2002, 01:38 PM Thread Starter
blackjeep
Thanks for all the replies they really helped me out.
post #9 of 10 Old 08-23-2002, 07:38 AM
TJx2
Even the wide tracks? I didn't know that.
Learn something new every day!
TJx2 is offline
post #10 of 10 Old 08-23-2002, 10:01 AM
CSP
Yes. In 1980 Jeep started using New Process transfer cases in all of the fullsizes including the pickups (all pickups are wide track). These transfer cases were all drivers side drop and this is why they switched sides on the front axles.
CSP is offline
82 cherokee cheif axle width Ironworker709 Full Size Jeep Forum 1 01-25-2010 09:43 PM
W/T and N/T width ThisGuyUKnow Full Size Jeep Forum 1 09-06-2009 03:12 PM
Jeep J20 width MR.CJ-7 Full Size Jeep Forum 2 05-26-2009 09:59 AM
What's the width of a waggy front axle? wheelinjames Full Size Jeep Forum 6 03-03-2008 05:48 PM
Axle width question sixshooter Full Size Jeep Forum 0 11-05-2005 10:57 AM
