Why is my flywheel hitting my starter? - JeepForum.com
post #1 of 3 Old 07-18-2010, 10:13 PM Thread Starter
77j20
1977 J-Series Truck
I replaced my starter after my truck sat for a few years and the starter froze up. Every since I have had an odd rattle when I am under load and give it gas. I narrowed it down to the starter and shimmed it with 2 flat washers on each bolt for a total of 4 flat washers. That seemed to fix it for the most part but occasionally it still hits. What is going on? I replaced the flexplate just before it was parked. Probably has about 1000 miles on the new flexplate. Should I throw another washer on each bolt? That seems like a lot of shimming to me.
edit: I guess I should add that I never had this problem with the old starter/new flex plate before the starter froze up on me.
1977 J-20 TeamRushed AMC 401, TH400, D44 front, D60 rear, 33x12.50R16.5 Mud Terrains, SOA, rear shackle flip.
77j20 is offline
post #2 of 3 Old 07-30-2010, 12:19 AM
carnuck
1984 J-Series Truck
Sounds like the auto parts store sold you a Ford starter instead of an AMC one!
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #3 of 3 Old 05-09-2013, 07:43 PM Thread Starter
77j20
1977 J-Series Truck
Just to update this incase anybody else runs into the same problem. I finally got the truck back on the road and started tracking down the cause of this. Turns out the little disk on the center of the torque converter that sits in the end of the crank was bent causing the flexplate to wobble.
77j20 is offline
steering hitting leaf springs zeekracing Full Size Jeep Forum 3 12-13-2009 12:58 AM
J2000 starter Ben328is Full Size Jeep Forum 2 08-06-2009 01:55 PM
360 & 401 Flywheel info needed monty97 Full Size Jeep Forum 6 03-30-2009 10:55 AM
starter GCX2450 Full Size Jeep Forum 4 05-11-2008 11:46 AM
1987 Grand Wagoneer Flywheel problems patrromig82 Full Size Jeep Forum 1 04-01-2008 02:00 PM
