Who has a fully locked rear? - JeepForum.com
post #1 of 11 Old 04-06-2013, 10:52 AM Thread Starter
revelc
1985 FSJ Wagoneer
I have welded my front D44 and am considering doing the same to my AMC 20. But two things hold me back.
One. I am worried it will eat the crap out of my rear tires during daily driving.
And two. I am wondering how the rear axle shafts would hold up.
I have a Wagoneer with a hot 401. Around 380 HP and 450 FT-LBS.
I am running 31"MT's and 3.31 gears.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #2 of 11 Old 04-06-2013, 06:43 PM
olliehopnoodle
1982 FSJ Cherokee
What kind of trails do you ride? I did a lot of stuff in a 4" lift waggy wit 3.31 gears and 31" tires. Great combo. I started with a ARB in the back and tossed an aussie up front. The few times I had ARB problems (electical/air) the Aussie up front did the job! But that was on 'easier' trails.
Basically it is a cost thing. Welding is free. The tires will wear down faster. A locker will cost more. So ask yourself 'How much driving do I do' and what kind of wheel'n do I do as well as 'will I want to upgrade axles later?'. Don't toss a bunch of money in an AMC if you think you want to do D60/14 bolt. I made that 'mistake'.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #3 of 11 Old 04-06-2013, 07:02 PM Thread Starter
revelc
1985 FSJ Wagoneer
I would be hitting some mid level trails in Gilmer TX's Barnwell park.
Occasionally power line roads.
And I will drive it about 40 miles a day round trip to work. Mostly country roads and highways.
Since you put it that way I might weld it, wait until it breaks, then replace it with a GM or D60
revelc is offline
post #4 of 11 Old 04-06-2013, 07:27 PM
GoodSteward
1979 FSJ Cherokee
Good luck, either way. Wouldn't want that weld to break on a highway to work, though. I think the detroit lockers can be had for under $600.
http://www.bjsoffroad.com/prod-830.htm
In the middle of difficulty lies opportunity. ~Einstein
GoodSteward is offline
post #5 of 11 Old 04-06-2013, 07:31 PM Thread Starter
revelc
1985 FSJ Wagoneer
I really don't like BJ's too much. I never had luck with ordering from them.
After 6 weeks of waiting for an Aluminum radiator, a Mallory hei, and other items totaling $1,000 I cancelled it because they couldn't tell me when they would get some of the parts to complete it.
I found an Aussie locker for around $300.
revelc is offline
post #6 of 11 Old 04-06-2013, 07:34 PM
GoodSteward
1979 FSJ Cherokee
After 6 weeks of waiting for an Aluminum radiator, a Mallory hei, and other items totaling $1,000 I cancelled it because they couldn't tell me when they would get some of the parts. To complete it.
Thanks. I have actually began my first full blown rebuild of an FSJ (how I ended up here), but have had good luck with Detroit in my past 4wd's. That is good to know about BJ's, by the way.
post #7 of 11 Old 04-06-2013, 07:49 PM Thread Starter
revelc
1985 FSJ Wagoneer
Well like he was saying, I'd hate to put a Detroit in the AMC 20 then swap it out. If I can find a D44 from another FSJ to replace it I would consider the Detroit because I could use it in the front too.
revelc is offline
post #8 of 11 Old 04-07-2013, 08:22 AM
olliehopnoodle
1982 FSJ Cherokee
I installed the aussie in my front d44. Since you don't change carriers I didn't have to mess with the gear alignment. I believe it is the same with an amc20. So for a few hundred bucks and some wrenching you might be able to have a locker that would fit your needs but you wouldn't be tossing a lot of money away.
post #9 of 11 Old 04-07-2013, 02:26 PM
1983Chief
I put an Aussie mechanical locker in my AMC 20 and it does great, i have a MCX 350 pushing close to 350 hp and never had any problems. I have close to 11,000 miles on it now.
1983Chief is offline
post #10 of 11 Old 04-08-2013, 07:49 AM
jeepdj5
1982 FSJ Cherokee
Don't weld the rear you will be putting rear tires on every month get a locker and put it in a bigger axel
if only gas was cheaper
jeepdj5 is offline
post #11 of 11 Old 04-08-2013, 04:56 PM
super98lsc
I had a spool in the 9" on my 63 galaxie convertible. Was awful on the street and destroyed tires. Complete misery in parking garages. Installed a Yukon posi works great.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
