What will interchange? - JeepForum.com
post #1 of 2 Old 12-16-2001, 12:45 PM Thread Starter
Dave
I have a 70 Wagoneer and want to put a pickup body on the running gear, anyone have any info? (HELP)
Dave is offline
post #2 of 2 Old 12-17-2001, 11:55 PM
Hump
Your wagoneer is a NT (narrow track) meaning the axles are shorter than a WT (wide track). All J-trucks and some Cherokees were WT, which I believe is 2" wider on each side. You will probably run into the width problem, as well as a wheelbase problem. If you don't mind cutting the frame, shortening drive shafts, and doing alot of relocating, then it's all up to your imagination.
You would probably be better off putting the Wag's running gear on the J-truck...minus the axles which wouldn't fit. Engines, trannys, and transfer cases are all interchangable. You would have to get adapters made for I6 to V8 swaps though.
Check out www.ifsja.org. The guys on the message forum could help you through anything.
'70 J4800 Buick 350/T18/D20/D44/D60
'90 MJ SWB 4.0L/auto/2wd (4wd conversion in the process)
'98 & '01 XJ Classics both with 3" Skyjacker & BFG AT KOs
Parting '99 & '00 XJ Sports
Hump is offline
stock Jeep alloy rim interchange onto 06 cmndr kevinhall Full Size Jeep Forum 0 12-09-2009 09:25 PM
1973 j4000 part interchange ?s mbrust Full Size Jeep Forum 5 11-23-2008 08:45 PM
What will fit? (Body Interchange) Dave Full Size Jeep Forum 1 01-03-2002 02:31 PM
