What is this device for? - JeepForum.com
post #1 of 8 Old 12-31-2013, 05:23 PM Thread Starter
Gante
I see this white thing connected to vacuum hoses, electric wires and a chain link to the carb ...
Gante is offline
post #2 of 8 Old 12-31-2013, 06:48 PM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
Cruise control
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline
post #3 of 8 Old 01-01-2014, 10:18 AM
olliehopnoodle
1982 FSJ Cherokee
Yep, that is your non-functioning cruise control.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #4 of 8 Old 01-01-2014, 11:56 AM
RockRollin
1990 FSJ Wagoneer
There should be another vacuum ball beside your master cylinder that connects to that loose vacuum line, then a line that goes to the vacuum ball on the fire wall. That line should have two t's in line, one to vacuum source (intake) one into the fire wall (next to the green and yellow vac lines), there is a black plastic vac line from the low port of the fire wall vacuum ball that goes into the fire wall about two inches below the other three.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #5 of 8 Old 01-01-2014, 12:21 PM
RockRollin
1990 FSJ Wagoneer
The line from the cruise controll goes on to the line behind the wire loom thingy.
Whoa, I think I'd rather shove snow down my pants than try to upload pics again
Sent from my SCH-I535 using JeepForum
"I like fun" Edd
post #6 of 8 Old 01-01-2014, 01:56 PM Thread Starter
Gante
On the first T connection on the fire wall vacuum ball, Where exactly is your vacuum source on the intake connection? Do you have a picture of the other end of that hose? Mine was connected to the air filter housing lines for the vacuum motors on the " lift gates " for the air filter.
Thank you for your help
Gante is offline
post #7 of 8 Old 01-01-2014, 05:10 PM
RockRollin
1990 FSJ Wagoneer
Well, I can't remember on my stock 2bbl intake, but I think its right behind the carb. It can be hooked into any manifold vacume port though.
"I like fun" Edd
post #8 of 8 Old 01-01-2014, 06:35 PM Thread Starter
Gante
Thank you. I connected mine to the intake port in front of the carb where I have my brake booster. There is a connector for the brake booster and another smaller connection.
Gante is offline
