Quantcast Wagoneer questions, something for everyone! - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Wagoneer questions, something for everyone!
Spartan Lockers FREE SHIPPING Excellent PricesDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ
Old 10-20-2008, 12:27 PM   #1
HeepToJeep
1982 CJ8
I have some Cherokee/Wagoneer/Grand Wagoneer questions for you folks.....
Converting to GM drivetrain
Any particular engine size you suggest?
Any particular model/year you suggest as a donor vehicle?
Should I go with a carburated system or fuel injected?
What kind of fuel milage does a GM powered Wagon get?
Is there a way to add fuel injection to one of the older, more powerful GM V8s?
What kind of towing capacity can be expected after such an upgrade?
Performance
How off-road capable are they?
Is the four-corner leaf spring setup flexy?
What are they best suited for? ie trail, swamping, rock crawling ect
Anyone ever seen one with front and rear COA conversion? How did it perform?
General
Are there any considerable advantages to one FSJ over the others?
Anyone happen to know how many cubic feet of interior space they have?
Are there any boneyard build/junkyard upgrade threads/lists anywhere?
Anyone seen or have photos of one that's had the top chopped?
I've currently got a couple of XJ Cherokees and am closing a deal on a Wrangler, while I really like the XJs I've never been a fan of unibody vehicles because they're disposable after a collision and I view them as pop cans. If you guys have any comments on the transition from XJ to FSJ please feel free to chime in.......
Wm
HeepToJeep is offline   Reply With Quote
Old 10-20-2008, 01:08 PM   #2
BJ's Off-Road
Vendor
BJ's Off-Road's Avatar
1979 FSJ Cherokee
I wouldn't go any smaller than a 350 if an old engine but the newer 5.3, 6.0 engines are really nice
Depends if you want fuel injection. I personally have a 350 TPI out of a Camaro which works well but I had to source the tranny and xfer case. Your best swap might be from a 2000-ish to 2008 Tahoe, Yukon, truck, Suburban, etc.
If money is no object, Fuel Injection
Depends on the engine, lift, tires, etc, etc. Originally when I did mine, it was a 305 TPI with the stock TH400 and Quadratrac (all wheel drive) and I was getting 18 MPG. When I went to the 350, I built it and lifted it and put 35's on it, etc, etc and I get about 10-15.
Older, more powerful? Like what? If you are looking at the pre-71 GM's, the numbers are mistaken as they changed the way they rate engines in 1971.
Before and after this conversion, you will still have a 1/2 ton truck so 6000 lbs maybe 8000 lbs would be max.
With a rear locker or posi, they are VERY capable. Size is the only restriction.
It can be, especially with a spring over in the front and a shackle reversal in the rear
Whatever you want them to do, you can build these to do whatever.
What is a COA? Do you mean SOA? If you do, the rear is already SOA'ed so you have to do a shackle flip, there is a nice kit to do the front and rear here:
http://www.bjsoffroad.com/CartGenie/prod-844.htm
Most have Dana 44's front and rear, V8 engine, strong automatic transmissions, A/C, power steering, room for the family, etc.
Good question, I don't know.
Do a google search for Trucks Bargain Beater and see if you can find a video that someone pirated on youtube or something
BJ's Off-Road
Specializing in Full-Size Jeeps -- 1984-1991 Grand Wagoneers, 1963-1988 J-trucks, 1974-1983 Cherokees and 1963-1983 Wagoneers!
Check us out on Facebook!
www.facebook.com/bjsoffroad
BJ's Off-Road is offline   Reply With Quote
Old 10-20-2008, 01:35 PM   #3
HeepToJeep
1982 CJ8
BJ,
To further upgrade the vehicle from a 1/2 ton all it would require is changing the axles to D60s or D70s but also based on vehicle weight and length would it tow similarly to a 3/4 or 1 ton?
COA is coil over axle, XJs have a COA front end and Wranglers are COA front and rear........it improves on-road comfort and off-road ability TREMENDOUSLY.
Price isn't an issue on which axles. engine, transmission or transfer case I use......my boneyard is flat rate so I pay the exact same price for an aluminum V8 from a Corvette as I do for a four-banger from a Hugo. As such, maybe I should go diesel? Duramax
Ever seen one with the top chopped and made to be removable like the old K5 Blazers?
My goal for the vehicle is daily driver, off-roading and towing project/parts vehicles home......obviously, good fuel efficiency and power are key.
Wm
Old 10-20-2008, 02:02 PM   #4
BJ's Off-Road
Vendor
1979 FSJ Cherokee
Yes, you could put larger axles in it, that would help but you are still running a relatively short rig (109" wheelbase) and the longer a vehicle is, the better they tow.
You could COA it but that requires a lot of modifications and probably a lot of trial and error to get it working correctly.
Hope this helps.
BJ's Off-Road
Old 10-26-2008, 01:49 AM   #5
carnuck
1984 J-Series Truck
Coils on an FSJ would lower it's weight capability. I have a '76 J10 shortbed which will be hauling my 5th wheel (27' long) with a 304 and J20 axles. No other major upgrades.
carnuck is offline   Reply With Quote
Old 11-04-2008, 10:39 AM   #6
HeepToJeep
1982 CJ8
Come on folks, no one else has opinions on the questions I posted? Here's a few more....
Anyone ever weld metal over the rear windows to turn it into a panel truck?
Are there any photos/links floating around that show how the rear interior is setup in factory panel trucks?
Are there any companies making barn doors for the rears these days?
What years were the panel trucks made?
I'm picking up a few Wagons to build one nice one from but am on the fence about setting it up as a panel truck or a removable hardtop with rollcage.....maybe a panel truck with a removable hardtop...hmmm
Wm
Old 11-16-2008, 02:08 AM   #7
carnuck
1984 J-Series Truck
Check out the build up of John Meister's panel truck with barn doors on http://wagoneers.com
Frankly, the flex of the Wag frame keeps it from being a 5th wheel hauler, unlike the Jtrucks which are built for more weight. My bone stock (except the rear axle from a J20) '73 J4000 hauled 6500lb loads regularly with just a 304.
Old 11-16-2008, 08:34 PM   #8
HeepToJeep
1982 CJ8
I've never been able to find anything on that website, man...talk about a navigation nightmare!
See any reason the Wagon frame couldn't be tied together better or the body dropped on a J-truck frame? I'd really like to have an older Jeep SUV with a higher towing capacity, preferribly a stock panel truck or a conversion. I've also been looking at Willys in the sales ads and find myself strongly tempted to get one and put the body on a chassis from something stronger and more modern to use as a daily driver....if the restoration buffs didn't gang up and beat me to death first lol.
Wm
Glock Forum
