The door lock and ignition keys were usually the same so you can pull off your door lock and have a locksmith make a key. When you open your door, look at the back edge of the door level with the key tumbler. You'll see a flat piece of metal in a slot. This is the clip that holds the tumbler in place. Pull that clip and the tumbler comes right out.
Patrick V.
Valparaiso, IN
73 Jeep J4000 360 .040 over, Summit K8600 Cam, Edelbrock Manifold and 750CFM 4V TH400/1339 QT
78 Cherokee Chief- Hunting Property Rig
05 Grand Cherokee- 3.7 V6 5 speed auto
