Wagoneer!@! - Page 2 - JeepForum.com
post #16 of 21 Old 03-21-2013, 05:56 PM
RockRollin
1990 FSJ Wagoneer
There are three primary components to the ignition, electronic ignition control box, coil, distributor. The control box sets close to the hood hinge, drivers side, atop the inner fender, its about 3"x5"x1.5". It sounds like that is what you have failing.
Upgrade options are many, hei, tfi, are the most common. TFI uses a control box and can be used with the working duraspark controller and distributor, its a coil, sparkplug wire different cap. TFI can also be used with a multispark controller (MSD). The HEI is the same story. What it gives you is "hotter" spark, better idle, better response, and some say better mileage.
That oil can coil is pretty old technology "50s" maybe
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #17 of 21 Old 03-22-2013, 07:57 PM Thread Starter
WagenWheels
1987 FSJ Wagoneer
Update... Thanks for all the help. Changed ignition coil, distributor, cap, rotor, ignition module. The stalling problem is gone. New problems arise...
1. I now have a knocking sound near #1 or near the fuel pump. I cant really tell what it is, it doesn't go away with speed or time. (could i have broke something while doing the distributor, because it wasnt the smoothest going project, i did it like 4 times to get it all lined up and firing correctly?)
2. I can rev up high and it all goes well in neutral, while driving if i accelerate fast it tries to stall and back fire, if i slowly increase speed with the pedal she does fine.
3. My initial warming up idle is way to high, i back the idle adjustment screw and the throttle will not go far enough to rest on it. I can push it back to where i want it, then it springs back.
4. I have rust everywhere, i will be taking care of that later.
WagenWheels is offline
post #18 of 21 Old 03-22-2013, 08:41 PM
pleontks
1976 J-Series Truck
sounds like timing
Beauty is in the eye of the jeepowner.
pleontks is offline
post #19 of 21 Old 03-22-2013, 09:38 PM
RockRollin
1990 FSJ Wagoneer
Originally Posted by pleontks View Post
sounds like timing
X2.
The initial warm up idle you speak of is not the same as idle. The "choke" or high idle adjustment is on the passenger side on the back of the butterfly.
Did you use your old distributor gear? This is VERY important due to the mesh of the gear. That knock your hearing could be the gears stress clocking.
"I like fun" Edd
post #20 of 21 Old 03-23-2013, 04:19 AM Thread Starter
WagenWheels
1987 FSJ Wagoneer
I did not use my old gears, should i swap it?
post #21 of 21 Old 03-23-2013, 06:16 AM
RockRollin
1990 FSJ Wagoneer
Yes. The gears (cam, distributor) are matched set, like ring&pinion. Pull the distributor and inspect the cam gear with a light, there should be no chipping or hard rubs on it. There is a pin that holds the distributor gear in place, drive out the pin, and swap the gears. Note which side is top on the gear and install the same way
"I like fun" Edd
