Waggy 44 fill plug help - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Waggy 44 fill plug help
Black Friday- Cyber Monday Deals at jeepHutBlack Friday Deals !JcrOffroad Black Friday Sale!
Unread Yesterday, 03:57 PM   #1
skizriz
skizriz's Avatar
1978 CJ7
I am in the process of installing Dana 44's from a Waggy (offset rear/pass drop front) under my CJ, and just noticed that the fill plugs on the diffs are different. I don't know which axle the covers came off of, and don't want to under fill one, and over fill the other.
Been looking on the interweb for pictures, but every one I see seems to be different.???
Anybody help me out? Right now I have the higher located plug on the front axle.
Here's a picture of the rear. I could only get a QT in it, even with the rear elevated.
Hard to tell in this picture, but the front plug is about 1/2 way up the cover, about mid axle tube.
78 CJ7 258 TH400/Dana18 SOA/stock YJ springs 35" General Grabbers.
skizriz is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:44 PM   #2
CSP
Fords with the high pinion 44 have the higher plugs.
CSP is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:04 PM   #3
skizriz
skizriz's Avatar
1978 CJ7
one of my covers has the plug higher than the other does. One is at mid axle tube, the other is below the axle tube. I didn't notice which was which until now, and don't know if I have them on the correct axles. Need to know if the way I have them is correct. The pictures I look at seem to show them all different.
Unread Yesterday, 10:19 PM   #4
CSP
I wouldn't think you could go wrong with any of them. If your pinion is pointed up it wouldn't hurt a thing to have more capacity to keep the pinion bearings happy.
Who's to say that someone who owned the axles before you didn't swap in different covers? Just food for thought.
Unread Yesterday, 10:45 PM   #5
skizriz
skizriz's Avatar
1978 CJ7
Could have been swapped along the way.
Im just paranoid about the rear being too low, and not getting enough oil. Especially after leaning it over, and having what little oil there is Drain into the tubes.
Sent from my HTC One SV using JeepForum
