Uggggh..Overheating and back fire Help! - Page 2 - JeepForum.com
post #16 of 21 Old 06-12-2013, 08:49 PM
megajeep
1989 FSJ Wagoneer
Replace the water pump. What else could it be since you've replaced everything else. Just do it.
megajeep is offline
post #17 of 21 Old 06-12-2013, 10:15 PM
jeeper54
Water pump is not a hard job. I make a template for the bolt location. Out of curiousity, have you checked timing? Where in phx. you located?
jeeper54 is offline
post #18 of 21 Old 06-12-2013, 10:55 PM
super98lsc
if its heating up that fast then the new stat is bad. Make certain you idle it with the cap off until it warms up all the way then you will see the water flowing across the top of the radiator and as the stat opens it will burp the air up and out. Then you can add more water until topped off and then place the cap on. The fan will only affect cooling under maybe 30mph, beyond that speed it should stay cool on its own from airflow. The water pump impellers on some pumps are pressed on and can slip internally also impeller corrosion will cause them to cavitate and have poor flow. You can test the coolant to see if hot exhaust gas from a bad head gasket or head is leaking into the coolant which will boil the coolant fast. Pull the plugs and check the electrodes they will show if coolant fouled also make certain that someone didn't put the 2 steps hotter heat range plugs in that the 70,s model 360s used. The later 80's 90's used a colder plug and a leaner mixture for emissions reasons the engine will run cooler and less detonation prone. Make certain the catalytic converter isn't blocked and that the exhaust heat riser on the passenger side manifold isn't stuck shut forcing hot exhaust to cross over through the intake 100% of the time. I wired mine open. Next check that the thermal actuators on the air cleaner snorkel are opening for full cold air and not grabbing preheated air off the passenger side manifold.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #19 of 21 Old 06-13-2013, 12:03 AM
jeeper54
super98isc covered what I was going to add. Are you going by the factory dash gauge or verified by other means?
jeeper54 is offline
post #20 of 21 Old 06-13-2013, 05:15 AM
RockRollin
1990 FSJ Wagoneer
Overheating and backfire points to lean condition.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #21 of 21 Old 06-13-2013, 08:34 PM
olliehopnoodle
1982 FSJ Cherokee
I would pull the new thermostat and test it in boiling water. I had one go bad and it was stuck 'just a little open'. Idled great, heated up right away on the highway. You could see water flow.
I live in AZ. I have a IR gun and timing light. We should check your timing. What general area do you live in?
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is online now
carburetor , heat , overheating , radiator , thermostat
No fire at ignition coil WoodyMS Full Size Jeep Forum 5 12-25-2010 07:14 PM
73 J2000 fire truck hokie CJ-7 Full Size Jeep Forum 0 06-12-2008 10:19 PM
fire gumba Full Size Jeep Forum 2 09-19-2007 10:07 AM
Jeep won't fire gsucooldude Full Size Jeep Forum 5 08-11-2003 10:12 PM
fire in the FSJ hole... lasarus Full Size Jeep Forum 2 03-31-2003 04:40 PM
