turning produces clunk? greased linkage still issue - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > turning produces clunk? greased linkage still issue
ORS4x4: New Product!Aluminum Quick Release Fire Extinguisher Mounts from ORS4xKinetic Recovery Rope from ORS4x4
Unread 10-26-2010, 10:38 AM   #1
Eric1080
1978 J-Series Truck
everytime i turn the steering wheel i get a loud clunk, both left and right turns. it turns fine but i feel something give and heard the noise. i greased the tie rods and drag link and lower ball joints. the tie rods seem to be fine. i also changed the power steering fluid a couple months ago. fluid is at good level. it just recently started doing it. ANY help will be greatly appreciated
Eric1080 is offline   Reply With Quote Quick reply to this message
Unread 10-26-2010, 11:55 AM   #2
BJ's Off-Road
1979 FSJ Cherokee
I would bet shackle bushings...
We have replacements here:
View the Shackle Bushings at http://www.bjsoffroad.com
Or a complete shackle here:
View the Shackle Assembly at http://www.bjsoffroad.com
Thanks.
www.bjsoffroad.com
BJ's Off-Road is offline   Reply With Quote Quick reply to this message
Unread 10-26-2010, 10:15 PM   #3
Eric1080
1978 J-Series Truck
the springs are newer and the bushings are good. im going to check the shackle bushings tomorrow.
Unread 10-27-2010, 09:17 AM   #4
CSP
So you greased everything, but have you checked any parts for wear?
CSP is online now   Reply With Quote Quick reply to this message
Unread 10-29-2010, 01:00 AM   #5
Eric1080
1978 J-Series Truck
i looked the tie rods over, and every greasable part. everything seems tight (relative).
Unread 10-29-2010, 10:22 AM   #6
megajeep
1989 FSJ Wagoneer
Last time I had a problem that sounded like that it was a ball joint.
megajeep is offline   Reply With Quote Quick reply to this message
Unread 10-29-2010, 10:52 AM   #7
Eric1080
1978 J-Series Truck
thats what im thinking. ball joints. the tires seem to point out at the top.
Unread 10-30-2010, 07:18 AM   #8
jamiedude
1989 FSJ Wagoneer
your not over extending because of the suspension lift are you? as in almost 3/4 steer it kunks! but nothing relatively irritates your actual steering? no sudden jerk in steering wheel?
jamiedude is offline   Reply With Quote Quick reply to this message
Unread 10-30-2010, 06:15 PM   #9
Eric1080
1978 J-Series Truck
no jerk in wheel. just the clunk that i can feel thru the floor boards. it still turns fine. it only does it at random. it will do it for a couple days then stop. then randomly start again in a few weeks if then.....
Unread 10-31-2010, 11:45 AM   #10
fuzz2010
On my YJ it was the end of the leaf springs "slipping" on each other. It would happen only every other day or so. Had my friend turn the wheel back and forth while I looked at the front end thinking it was something else. Have someone do this for you and you can at least look for something wrong.
fuzz2010 is offline   Reply With Quote Quick reply to this message
Unread 03-24-2011, 01:34 PM   #11
Eric1080
1978 J-Series Truck
had the wife turn the wheel while i looked underneath. of course it didnt do it then. BUT i did notice the leaf springs are no together. they seem to be coming apart (one more to the right and one more to the left). these are newer springs with poly bushings and they still have the plastic shims in between but seem to be twisting out of place. anybody know what causing this and how to fix it???
Unread 04-04-2011, 07:20 PM   #12
Eric1080
1978 J-Series Truck
found it. it was the leaf springs twisting apart from each other. anyone know how to fix this issue? seems to be getting worse.
