Transmission slow - JeepForum.com
post #1 of 5 Old 09-27-2010, 03:07 PM Thread Starter
wagoneerpioneer
1987 FSJ Wagoneer
Transmission slow
Hey everyone,
My 87 Wagoneer's transmission isn't shifting properly. Its an automatic and when putting it in drive it will go into neutral before catching the right gear. Even while driving, when it is shifting to a higher gear it seems to get caught in neutral. There's enough ATF as well. Does this sound familiar to anyone else, and is there a way fix it?
Thanks!
wagoneerpioneer is offline
post #2 of 5 Old 09-27-2010, 06:27 PM
megajeep
1989 FSJ Wagoneer
It sounds like you need a band adjustment. If you dont have a manual, you should be able to find instructions on the web.
Here is a great page for reading about the torqueflite 727.
Tom Hand's guide to the Chrysler torqueflite automatic transmission
megajeep is offline
post #3 of 5 Old 09-27-2010, 08:01 PM
BJ's Off-Road
1979 FSJ Cherokee
1987 Wagoneer or 1987 Grand Wagoneer?
www.bjsoffroad.com
BJ's Off-Road is offline
post #4 of 5 Old 09-27-2010, 08:51 PM Thread Starter
wagoneerpioneer
1987 FSJ Wagoneer
1987 Grand Wagoneer
post #5 of 5 Old 09-29-2010, 12:29 PM
carnuck
1984 J-Series Truck
Sounds like clogged filter or hard seals. Drop pan and clean filter with new fluid. If that doesn't get it or there is a TON of material in the pan, a can of STP engine oil treatment may make it hold together till you can afford a trans swap.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
transmission , wagoneer
Transmission????? leebowles Full Size Jeep Forum 8 02-21-2010 01:00 PM
5.9 cranking slow lazyguy Full Size Jeep Forum 16 11-12-2009 07:16 PM
wipers slow start in cold CARVINSTARVIN Full Size Jeep Forum 0 08-23-2007 11:38 PM
slow wipers on 88 wagoneer redoctober Full Size Jeep Forum 0 03-30-2007 07:02 PM
what transmission does it have? tate228 Full Size Jeep Forum 1 06-21-2005 09:49 AM
