Transmission????? - JeepForum.com
post #1 of 9 Old 02-20-2010, 11:14 AM Thread Starter
leebowles
1990 FSJ Wagoneer
Transmission?????
OK, I have been working on my 90 wagoneer for a few month, and have it running like a top..
Runs great, but doesnt move..I can hear it changing from park to reverse and reverse to drive, but nothing...When I go to put in back in park, i hear grinding gears...
I've check linkage, its good.
NO broken axles..
I am hoping for a quick, easy and cheap fix...
Tranny color and fliud levels look good...
I really dont want to get new or rebuilt tranny, any help you give would be appreciated.
Thanks,
Lee
leebowles is offline
post #2 of 9 Old 02-20-2010, 01:21 PM
semikrazy
1977 CJ7
The transfercase is in neutral.
semikrazy is offline
post #3 of 9 Old 02-20-2010, 02:09 PM
gnarlytoes
1977 FSJ Cherokee
gnarlytoes is offline
post #4 of 9 Old 02-20-2010, 02:09 PM Thread Starter
leebowles
1990 FSJ Wagoneer
WOW!!! I didnt think of that!! Does it need to stay in 4H? unless mudding?
Thanks
I really know nothing about 4x4's...I know I have some issues with the vaccums. It wont switch from 4 to 2 wheel drive.. Also, there is a 5/8?? hose coming from the top of the front axle, and I'm not sure where it goes..
I really appreciate the help..
Lee
post #5 of 9 Old 02-20-2010, 03:34 PM
semikrazy
1977 CJ7
If your Jeep is a quadatrac then it is a full time 4x4. and was meant to be driven in 4x4. The lever under the driver seat is for low/neutral/high gears. Use high gear for everday driving. the switch in the glove box is used for locking the front and rear together and only to be used if on slick surface. As for the hose going to the front diff it may be for a vent.
post #6 of 9 Old 02-20-2010, 06:14 PM
gnarlytoes
1977 FSJ Cherokee
The '90 model will have 727 trans and 229 transfer case. It has 2H, 4H, N, 4L. The front differential has a vacuum operated locker. If it is not working, you will only have 2wd, but the truck will still move with power to rear axle. The hose you are talking about is an axle vent and should have a vent plug in the end. It should have a clip on it that attaches to the lower radiator bolt.
Try this... chock the front tires and lift both rear wheels clear of ground and see if you can turn them by hand with the trans in park. You should not be able to turn them with the transmission in park. If you can, then try putting t-case in different range.
post #7 of 9 Old 02-20-2010, 09:00 PM
carnuck
1984 J-Series Truck
No vacuum front axle (it's solid because after '86 they became shift on the fly. Easy to spot because they don't have the pin that takes 2 hands to switch from 2wd to 4wd or vice versa), no vacuum operated locker (from the factory) in '90. I agree the tcase is likely bumped into neutral. With the truck not running, pull up the floor lever and see if it goes! (2wd is all the way up or all the way down, depending which tcase)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #8 of 9 Old 02-20-2010, 09:05 PM Thread Starter
leebowles
1990 FSJ Wagoneer
ok...the transfer case was in neutal. Its still to working ok...I just dropped the pan and replaced the filter, going to put new fluid in tomorrow.
I did jack the rear up, it didnt move in park. Also, I jacked the front and when I turned one wheel, the other turned to opposite way. I am beginning o think that I will be driving on 4x4 always, or until I get the vaccum lines fixed.
Do you have any suggestions of where I may get a vent plug???
fyi, it is select a trac not quad.
You have been very helpful.
Thanks,
Lee
post #9 of 9 Old 02-21-2010, 12:00 PM Thread Starter
leebowles
1990 FSJ Wagoneer
I drove it for about 10 miles today..Damn, I was happy guy, my wife couldnt have been less interested...LOL!
Replacing Transmission 2JeepsDeep Full Size Jeep Forum 5 06-16-2008 12:25 PM
83 wagoneer transmission bturnerexpress Full Size Jeep Forum 4 04-09-2008 02:36 AM
Transmission Pan removal on a 79 J10 cascios Full Size Jeep Forum 5 01-19-2008 08:16 PM
Which transmission? JOKER4INK Full Size Jeep Forum 2 10-03-2005 09:57 AM
what transmission does it have? tate228 Full Size Jeep Forum 1 06-21-2005 08:49 AM
