tranny swap?? - JeepForum.com
post #1 of 2 Old 04-11-2011, 02:12 PM Thread Starter
Zorm
1983 FSJ Cherokee
tranny swap??
OK, I know we're all SJ guys, but maybe some of you have little jeep experiance.
I have a 1983 SJ Cherokee 4 door. Right now I am in the process of swapping out the 4.2 for a 4.0 with the MPFI. I was going to keep the T176 and just get the bell housing machined for the CPS but then found an AW4 close by for sale.
What would be the pros and cons for swapping out the T176 for the AW4?
Would my NP 208 bolt up the AW4 or would I need an adapter plate?
The AW4 I found is from an 89 wrangler, what mods or electrical connections would I need to consider mating this up to a 4.0 and wiring harness from a 92 Cherokee that had an AW4?
(I know the AW4 is an auto)
Zorm is offline
post #2 of 2 Old 04-11-2011, 09:29 PM
jimk403
2009 JK Wrangler
I'm pretty sure the '90 model computer and wiring harness are different than earlier 4.0/AW4 models. Don't think you could use the '92 stuff with an '89 engine. I swapped a 4.0 from an '88 XJ Wagoneer to an '88 XJ Cherokee and some of the wiring was different. Jeep used a different fuel injection system starting around '90, so the computer is not the same.
Hope this is not as confusing as it looks.
Just my opinion, yours will differ.
Proud owner of: '09 Rubicon Unlimited, '90 XJ, '88 XJ, '77 J-10
jimk403 is offline
Tranny swap in 86 GW? wyotechgrad2010 Full Size Jeep Forum 4 01-18-2011 05:33 PM
what tranny do i have? FleXXedOUT88 Full Size Jeep Forum 5 01-10-2009 12:24 AM
tranny swap bdb12586 Full Size Jeep Forum 0 08-05-2007 07:31 AM
tranny martinpl Full Size Jeep Forum 0 09-07-2006 09:11 AM
Possible Tranny Swap? betts1 Full Size Jeep Forum 6 08-19-2005 12:28 PM
