Tranny Fluid - JeepForum.com
post #1 of 2 Old 09-24-2002, 10:00 AM Thread Starter
Mysta_Killa
Tranny Fluid
I have a 84 Wagon with a 2.5l, what type of tranny fluid is used in these vehicles?
Thanks
Mysta_Killa is offline
post #2 of 2 Old 09-24-2002, 11:54 AM
ageofzeppelin
Since you have the 2.5L, it leads me to believe you have a Wagoneer that is essentially an XJ Cherokee. If this is the case, you have two options. If it is an auto transmission, just get some ATF fluid and fill it up. Otherwise, get some gear lube that won't corrode the metals inside your tranny (ie, look at the owner's manual to see what it recommends) You should probably be OK if you were to use Pennzoil Synchromesh or Redline MT90.
1993 XJ Sport
4.0L, HO
5-speed Manual
235's and a few other little things.
ageofzeppelin is offline
ATF Fluid compatibility twmattox Full Size Jeep Forum 3 01-19-2010 09:37 PM
diff fluid scrounge Full Size Jeep Forum 2 07-18-2009 08:51 PM
Dana 44 - required fluid thejudge Full Size Jeep Forum 5 01-21-2009 07:39 AM
Fluid questions (Oil and Transmission) DukeJeep Full Size Jeep Forum 2 01-12-2009 12:20 PM
diff fluid jeepwcrazy Full Size Jeep Forum 5 03-20-2008 12:30 PM
