Trandfer Case doing funny things - JeepForum.com
post #1 of 8 Old 11-10-2008, 08:57 AM Thread Starter
shiner1
Hi All:
When starting from a stop my 1984 G. W. will sometimes seem to be
disengaged, in that the engine will rev but no movement. When this
happens there will be a chattering like gears meshing and then there
is engagement and it moves. The noise seems to come from the
transfer case. This does not happen all the time but is intermittent
thing.
Any ideas out there.
Shiner1
shiner1 is offline
post #2 of 8 Old 11-10-2008, 10:59 AM
BJ's Off-Road
1979 FSJ Cherokee
What kind of xfer case is it? There is a tag on the back of it to ID it.
www.bjsoffroad.com
BJ's Off-Road is offline
post #3 of 8 Old 11-10-2008, 01:10 PM Thread Starter
shiner1
Thanks for the reply BJ
Sorry about the omission. It's a Model 229.
Shiner1
shiner1 is offline
post #4 of 8 Old 11-10-2008, 03:44 PM
BJ's Off-Road
1979 FSJ Cherokee
Has it been run in 4WD without the front hubs locked?
www.bjsoffroad.com
post #5 of 8 Old 11-10-2008, 06:24 PM Thread Starter
shiner1
BJ to my knowledge it has not been run in four wheel drive with the
hubs unlocked. It was run in four wheel drive alright just before
this condition raised it's ugly head after going back to two wheel
high.
Shiner1
PS: Thanks for the reply.
shiner1 is offline
post #6 of 8 Old 11-11-2008, 09:34 AM
BJ's Off-Road
1979 FSJ Cherokee
Talked to one of the guys here who knows NP229's really well and here is his response:
on that, it could be the linkage out of adjustment (typically look at the rubber / poly shift linkage bushings), but could also be low fluid (they take Dexron-Mercon II or III, either /or) or the viscous coupler low on fluid. Best bet is to drain the fluid with a light behind it as it drains, so he can see through the fluid.....watch for globs of silicon-gel coming out......if so, viscous coupler is probably toast.
Hope this helps.
www.bjsoffroad.com
post #7 of 8 Old 11-11-2008, 10:59 AM Thread Starter
shiner1
O. K., thanks for the reply BJ, very much appreciated. Makes sense
to me. I now have a place to start.
Shiner1
shiner1 is offline
post #8 of 8 Old 11-16-2008, 01:25 AM
carnuck
1984 J-Series Truck
Vacuum motor is probably not fully engaging. I found a new one at work (NAPA) if BJ's doesn't have them.
carnuck is offline
Things to look for in a Grand Wagoneer StreetJeep Full Size Jeep Forum 1 08-19-2009 11:40 PM
New Jeep, New Forum...Things is wonderful! Stumpfoot Full Size Jeep Forum 3 06-12-2009 09:43 AM
Which transfer case with T18-1B? poppaw-2 Full Size Jeep Forum 3 06-04-2008 01:13 AM
Waggy T-Case Muddy Tj Zack Full Size Jeep Forum 2 05-03-2006 01:45 PM
Best T-Case? gunnerdog Full Size Jeep Forum 4 11-23-2005 08:22 AM
