Trail rating - JeepForum.com
post #1 of 12 Old 02-05-2013, 09:00 PM Thread Starter
Wiley2589
Trail rating
Would my 1983 wagoneer be considered to be trail rated?
Wiley2589 is offline
post #2 of 12 Old 02-05-2013, 09:56 PM
cookingguy
1979 FSJ Cherokee
darn skippy its a JEEP!!!! It can do anything and go anywhere!!
cookingguy is offline
post #3 of 12 Old 02-06-2013, 02:44 AM
RockRollin
1990 FSJ Wagoneer
This whole trail rated things only applies to those baby Jeeps. Hell everything AMC JEEP made back then was trail rated, even the cars. My older brother had an Eagle wagon that would flat out embarrass a Blazer off road.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #4 of 12 Old 02-06-2013, 07:56 AM
timgr
1975 CJ6
What's Trail Rated mean, besides being a marketing term?
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #5 of 12 Old 02-06-2013, 08:12 AM Thread Starter
Wiley2589
Trail rating means that a vehicle has passed off road testing by the Nevada Automotive Test Center which evaluates vehicles for traction, ground clearance, off road articulation, maneuverability, and water fording.
post #6 of 12 Old 02-06-2013, 08:14 AM Thread Starter
Wiley2589
It is explained on the website jeepfan.com
post #7 of 12 Old 02-06-2013, 09:30 AM
olliehopnoodle
1982 FSJ Cherokee
Technically no. The term came around after your wagoneer was built.
A stock 1983 wagoneer is a good trail vehicle. It has stock 4wd, either part time or full time with a low range. Decent articulation. Okay ground clearance. A stock wagoneer with can tackle most easy to easy-moderate trails with little to no problem and probably no body damage. A skilled driver could probably do most moderate trails.
The lack of a locker (some did come with limited slip), ground clearance and a not exceptional departure angle does impact the trail worthyness of our rigs.
The addition of a mild lift (4" springs), larger tires (31") go a long way to improve the types of trails/obsticles a wagoneer can handle. Toss on some rock sliders and a locker or two and you will be able to handle moderate to mildly difficult trails.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #8 of 12 Old 02-06-2013, 10:12 AM Thread Starter
Wiley2589
Thanks very much for the info. That helps a lot.
post #9 of 12 Old 02-06-2013, 10:17 AM
Dumpy
1972 J-Series Truck
I chuckled
'96 ZJ
'72 Jeep J2000 Pickup
Dumpy is offline
post #10 of 12 Old 02-06-2013, 02:06 PM
CSP
Trail rated means it's capable of going over curbs at the mall. That's where you're most likely to see vehicles bearing that badge.
CSP is offline
post #11 of 12 Old 02-06-2013, 02:22 PM Thread Starter
Wiley2589
That is so true!
post #12 of 12 Old 02-06-2013, 02:52 PM
Dave145
1976 FSJ Cherokee
In terms of these old jeeps, trail ready refers to the trail of import cars you can crawl over in a parking lot
Dave145 is offline
