Towing a 76 J10 w quadra trac - JeepForum.com
post #1 of 16 Old 04-08-2013, 01:50 PM Thread Starter
HC-Texas-J10
1976 J-Series Truck
Any issues or concerns in towing the Jeep behind a pickup? I have a good hitch, but I'm not sure how to deal with transmission. Would I simply put it in neutral as it's being towed? I have a about a 4 hour tow ahead of me.
Thanks
HC-Texas-J10 is offline
post #2 of 16 Old 04-08-2013, 02:41 PM
79chiefs
1988 XJ Cherokee
How are you towing, best to take all wheels off the ground.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #3 of 16 Old 04-08-2013, 04:14 PM
revelc
1985 FSJ Wagoneer
Thanks
If its an automatic that can burn the tranny and transfer case up. If your pulling without a trailer your only safe bet is to take the 15 minutes to remove the front and rear shafts.
Unless you installed lockout hubs in the front. Then you'd just unlock the hubs when towing and only pull the rear shaft. But make sure you relock the hubs when you arrive or you'll blow the t-case up.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #4 of 16 Old 04-08-2013, 04:43 PM
79chiefs
1988 XJ Cherokee
95 E34 540i-DD
79chiefs is offline
post #5 of 16 Old 04-08-2013, 05:52 PM
RockRollin
1990 FSJ Wagoneer
REMOVE BOTH DRIVE SHAFTS!!!!!
Check post 11 from tsm
http://www.ifsja.org/forums/vb/showt...=towing+q-trac
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #6 of 16 Old 04-08-2013, 06:23 PM
revelc
1985 FSJ Wagoneer
If he puts lockout hubs in the front he will only need to remove the rear, right?
revelc is offline
post #7 of 16 Old 04-08-2013, 06:39 PM
RockRollin
1990 FSJ Wagoneer
Yes that's correct. Tires need to be disconnected from t-case in some fashion.
"I like fun" Edd
post #8 of 16 Old 04-09-2013, 10:28 AM
timgr
1975 CJ6
Don't put locking hubs on a Quadratrac Jeep unless it's been converted to part time. Someone will try to drive it with the hubs unlocked, and ruin the transfer case.
If you own a Quadratrac Jeep, read the Owner's Manual about towing. Never leave your Jeep where it might get towed away either - towing on two wheels will ruin the transfer case ... and replacements are very scarce today.
You can tow with ALL FOUR WHEELS on the ground (emergency flat towing), only if you can unlock the steering column, transmission shifter in park, emergency drive at normal position, and put the transfer case low range in neutral. If no low range unit, you cannot flat tow like this.
The only other safe options are to remove both driveshafts, or raise the front and remove the rear drive shaft, or raise the front and put the rear on a dolly.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #9 of 16 Old 04-09-2013, 10:58 AM
revelc
1985 FSJ Wagoneer
Like I stated above. He would need to immediately engage the hubs before he drove or he'd blow up the t-case but he could do it without converting to part time and front hubs.
revelc is offline
post #10 of 16 Old 04-09-2013, 11:04 AM
timgr
1975 CJ6
Yes, you could do it. And it would be fine as long as you did not try to drive in normal drive with the hubs locked out.
But I felt compelled to point out that it's a risky idea IMO. Will you check that the hubs are locked every time you drive it? Will you know what's wrong when the engine revs and the car only moves slowly? Will you ever let someone else drive the car who might not understand the issue?
timgr is offline
post #11 of 16 Old 04-09-2013, 11:26 AM
revelc
1985 FSJ Wagoneer
I don't see any issues arising as long as he only disengages the hubs to tow then relocks them.
It's the cheapest fix and safe if he takes the time to think.
revelc is offline
post #12 of 16 Old 04-09-2013, 11:52 AM
CSP
What about the neighborhood kids that see those dials and decide to turn them?
CSP is offline
post #13 of 16 Old 04-09-2013, 12:07 PM
revelc
1985 FSJ Wagoneer
Do you not park inside a moat filled with sharks with lasers mounted on them?
revelc is offline
post #14 of 16 Old 04-09-2013, 02:28 PM Thread Starter
HC-Texas-J10
1976 J-Series Truck
Thanks guys. Don't mean to ask a rookie question, but is removing the drive shafts an easy endeavor? Otherwise, it seems I should just get a trailer...and tow accordingly.
post #15 of 16 Old 04-09-2013, 02:35 PM
CSP
Yes, it's pretty easy. Four nuts at each of of each driveshaft. Just don't lose the ujoint caps and/or the needle bearings under them. I duct tape the caps on as soon as each end is removed from the yoke.
CSP is offline
