torque convertor cover needed? - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > torque convertor cover needed?
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 01-14-2012, 02:52 PM   #1
Eric1080
1978 J-Series Truck
do i need a torque convertor cover for my th400? tranny makes ticking sounds on low rpm in every gear. i checked fexplate for cracks and for tightness of bolts. i cant find any issues. i took the cover off and sound went away. out it back on and came back. it may be bent from rocks and contacting flexplate????
Eric1080 is offline   Reply With Quote
Unread 01-16-2012, 08:01 AM   #2
Eric1080
1978 J-Series Truck
i took off the cover again and the noise went away. flexplate looked like it had wear marks on some of the teeth but no marks on the cover.
Unread 01-16-2012, 12:57 PM   #3
pleontks
1976 J-Series Truck
I haven't had one of those on a truck since i've started working on em
Beauty is in the eye of the jeepowner.
pleontks is offline   Reply With Quote
Unread 03-18-2012, 09:44 AM   #4
Eric1080
1978 J-Series Truck
the 3 bolts holding the flexplate on are defenietly worn a little. nice and shiney. what is causing this? bad tranny mount or something else? btw the tqc cover is still off
Unread 04-09-2012, 07:41 PM   #5
carnuck
1984 J-Series Truck
sounds like a dent in the cover allowing the bolts to contact.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'82 Honcho Sportside project 360 4 speed NP208 $1500
'81 Eagle wagon with upgrades $2800
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3000
carnuck is offline   Reply With Quote
Unread 04-11-2012, 12:22 AM   #6
jeeppwner
Agreed with Carnuck.. Has to be
jeeppwner is offline   Reply With Quote
Unread 04-11-2012, 07:16 AM   #7
Eric1080
1978 J-Series Truck
the cover is off so.... they dont appear to be getting an shinyer (sp?) guess ill just run it til it breaks something. the tranny sounds like its slipping/ shuddering in 1st gear anyways and i checked the fluid and only saw a little bit of crud on the bottom of the pan when i dropped it.
Unread 04-11-2012, 11:25 PM   #8
jeeppwner
At this point ,, be prepared to change it again soon.. I would assume the tranny was neglected. if it was all this new fresh fluid will clean up more corrosion and gunk in side your tranny and possibly clog your new filter again.. So if its not to late buy a drain pan with a plug at least. maybe better be safe then sorry..
Unread 04-12-2012, 07:12 PM   #9
Eric1080
1978 J-Series Truck
the tranny was decent when i got it. red fluid. i added a b&m cooler to help with the heat especially offroading. im about to add some Lucas tranny fluid to it and hope it helps. the b&m deep pan was on it when i got it and ive changed the fluid when i got it. its only been 8000 miles since ive had it. i kinda drive it like i stole it so i guess thats what i get
Unread 04-20-2012, 11:44 AM   #10
Eric1080
1978 J-Series Truck
do torque converters expand when warm?
Unread 04-20-2012, 09:19 PM   #11
pleontks
1976 J-Series Truck
I don't think so. Maybe try a different cover. yours could be tweaked just enough to rub
Unread 04-21-2012, 06:27 AM   #12
Eric1080
1978 J-Series Truck
i drove the truck a lot yesterday. transmission shifts fine. everything feels ok. i added a bottle of lucas tranny additive just to be safe. it makes the noise less. i noticed that it makes the noise after coming down a hill and stopping at a light or stop sign. it makes it in 2 areas, but way quieter now and it goes away quicker. maybe i just needed to drive it more or do 90 on the interstate
Unread 07-11-2012, 05:57 AM   #13
Eric1080
1978 J-Series Truck
bringin back the thread: flexplate is cracked. i saw it for sure. so i either take it in and pay$$$ or learn something new. my haynes manual makes it seem like a time consuming project but not hard. any thoughts? btw its a dd since i sold the honda
Unread 07-27-2012, 08:18 PM   #14
Eric1080
1978 J-Series Truck
update for those searching online and find the same problem and like most other posts just end with no answer. flexplate was cracked so i got a new one. if our tranny shifts fine but hearing metallic screeching sounds than check your bolts and flexplate
