Timing help - JeepForum.com
post #1 of 3 Old 04-28-2013, 07:36 PM Thread Starter
Chrisv102581
1979 J-Series Truck
Timing help
I have a 79 j10 with a 360. I just installed the edelbrock performer package. I'm having some problem stilling the timing at what degree should I set the timing without the vacuum advance?
Chrisv102581 is offline
post #2 of 3 Old 04-29-2013, 02:42 AM
RockRollin
1990 FSJ Wagoneer
If it were stock, it would be 8 (auto) 5 (man). However its no longer stock, so optimum timing may not be the same. I will suggest timing by peak manifold vacuum, rather than timing light.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 3 Old 04-29-2013, 05:12 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Bump up the initial timing till it pings under load or you feel the performance begins to drop off, then drop it back a couple of degrees. Keep an eye on it to insure it doesn't kick back while cranking or overheat on hot days. Most times you will land in the 8 to 12 BTDC range.
jeepdaddy2000 is offline
