TH400 no reverse - JeepForum.com
post #1 of 9 Old 09-24-2004, 11:08 PM Thread Starter
95YJnh
TH400 no reverse
i have a 1977 jeep cherokee 2-door with a 360 cid v-8 th400 tranny with the all wheel drive. i am planning on making it in to a trail truck because the body is rotted. the problem is that it doesnt have reverse or neutral ? its always in drive even in park it will try to move. is there away to fix it with out having it rebuit ? any info will help.
95YJnh is offline
post #2 of 9 Old 09-25-2004, 06:53 PM
wild_weazel
wild_weazel's Avatar
I just rebuilt a 700r4 for my wrangler and when I had that apart, there was nothing that I could see, for your problem. I think you will have to get it rebuilt. Call a couple of your local tranny shops and ask them what they think. I prefer the smaller mom and pop joints because they wil lhelp you out more than the bigger places. Good Luck
wild_weazel is offline
post #3 of 9 Old 09-26-2004, 08:33 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Might check to see if the shift linkage is out of adjustment.
jeepdaddy2000 is online now
post #4 of 9 Old 09-27-2004, 11:16 PM Thread Starter
95YJnh
nope there is no linkage left i thought that might be the problem so i cut the floor and removed the linkage a shifted at the tranny but it wasnt that
thanks
95YJnh is offline
post #5 of 9 Old 10-06-2004, 07:10 AM
superjoe
superjoe's Avatar
i might have a body for you if you are interested. i dont know what it looks like but it is a 73 and i am getting it for the axles and springs and possibly the motor. but it does not have a tranny and i dont think it has the t-case but not sure.
Joe Clark 210-639-0276
/l ,[____], 82 CJ 8 Scrambler Currently all stock but that will change.
l---L--0lllllll0-
()_) ()_)----)_)
superjoe is offline
post #6 of 9 Old 08-08-2007, 06:32 PM
Brianmac
Junior Member
Brianmac's Avatar
I have this exact same problem !!! Help anyone? Modulator maybe?
Brianmac is offline
post #7 of 9 Old 08-09-2007, 02:08 PM
JPJeeper
1972 CJ5
Go over to IFSJA.org
2006 Unlimited Rubicon
1990 Wrangler YJ
1987 Wagoneer FSJ
1975 J20 Jeep Truck
1967 J3000 Jeep Truck
JPJeeper is offline
post #8 of 9 Old 10-04-2008, 01:46 PM
1979jeepj10
1979 J-Series Truck
check vacume lines from engine to trans. I had same problem with mine when I got it and found the line(s) disconneted
1979jeepj10 is offline
post #9 of 9 Old 10-12-2008, 08:32 PM
rlaa
1983 CJ7
It sounds like some one had the valve body off and didn't put the shift selector linkage back on the piston. You'd have to drop the pan to see if the piston is moving back and forth when you move the selector.
83 CJ7 258 4spd, black top, yellow middle
rlaa is offline
th400 to chevy 208 79cherokee4x4 Full Size Jeep Forum 7 01-22-2010 10:39 PM
swap internals from amc th400 to sbc th400 Phoenix916 Full Size Jeep Forum 1 08-06-2009 01:02 PM
th400 Q's McWood Full Size Jeep Forum 2 04-25-2009 08:22 PM
th400 question? j w griffith Full Size Jeep Forum 2 03-20-2009 02:15 PM
Need th400 for 77 chief akennedy1984 Full Size Jeep Forum 1 07-28-2005 09:31 AM
