TH 400 questions - JeepForum.com
post #1 of 3 Old 05-28-2008, 04:28 PM Thread Starter
this_guy
TH 400 questions
Hello. I recently purchased a 1976 J-10. I need to purchase the spacer that goes between the filter and the valve body. Also, I would like to purchase the correct pickup tube and o-ring. I am having problems getting these parts through my local auto parts stores. Does anyone have a suggestion for where to order these online? Also, I need some TCL-1 for the BW1339. I appreciate any tips, websites, etc. I'm looking forward to getting the Jeep back on the road.
this_guy is offline
post #2 of 3 Old 05-29-2008, 09:18 AM
J4GRAND
What spacer are you referring to? I have never seen a spacer on the filter mounting bolt. The filter hangs loosely on the mounting bolt so it can float up or down depending on fluid level. Go to the Int'l Full Size Jeep Assoc. www.ifsja.org and you may be able to find the other parts. As for the QT fluid, you can order it through BJ's Offroad or make your own fluid by mixing 3 quarts of 30W non-detergent motor oil and 8 oz of limited slip additive.
Patrick V.
Valparaiso, IN
73 Jeep J4000 360 .040 over, Summit K8600 Cam, Edelbrock Manifold and 750CFM 4V TH400/1339 QT
78 Cherokee Chief- Hunting Property Rig
05 Grand Cherokee- 3.7 V6 5 speed auto
J4GRAND is offline
post #3 of 3 Old 05-29-2008, 10:52 AM Thread Starter
this_guy
I was referring to the spacer between the filter and the valve body, but I'm starting to gather that this spacer is only used with the deep pans. So, new question, if the filter is moving up and down with fluid level, what maintains the connection between the filter and the pickup tube? The o-rings? seems like the pickup tube would constantly be coming disconnected from the filter.
Thanks for the links.
this_guy is offline
Body rust questions & Dynamat questions bigdawgfan Full Size Jeep Forum 0 01-22-2009 07:16 PM
A few questions........ Arcticcat843 Full Size Jeep Forum 4 04-10-2007 02:51 PM
J20 questions soxcloud Full Size Jeep Forum 5 03-12-2007 12:33 AM
GW Questions Weelspin Full Size Jeep Forum 1 01-06-2006 10:10 AM
New Guy Questions.... lasarus Full Size Jeep Forum 1 11-13-2002 09:51 AM
