tailight,turn signal help?? - JeepForum.com
post #1 of 8 Old 10-05-2013, 04:21 PM Thread Starter
champb00
1981 FSJ Cherokee
just got this jeep, tail lights(middle bulb) stays on all the time. check ground , pulled light switch out and unpluged it still they are on. pulled fuse marked tail still on. only way to get them to go off is pull the fuse marked haz stop??
turn signals wont work at all. haz one will all work. changed the haz blinker but couldnt find another one for just the turn signal.
guys any help would realy help here. bein chasin wires and un wraping them but nothing seem to be it??
champb00 is offline
post #2 of 8 Old 10-05-2013, 11:25 PM
RockRollin
1990 FSJ Wagoneer
Check for a trailer plug, it could be causing a cross connection
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 8 Old 10-05-2013, 11:27 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Brake light switch out of adjustment?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 8 Old 10-06-2013, 09:10 AM Thread Starter
champb00
1981 FSJ Cherokee
i thought that could be it on trailer plug. so i took all the wires off that were extra or add ons. I will check brake adj today. any idea on turn lights? is there 2 flashers on a 81 jeep cherokee
champb00 is offline
post #5 of 8 Old 10-06-2013, 03:52 PM
jeeper54
Should be 1 flasher for turn signals & 1 for hazards. Since the lights are on all the time and only on the rear, try disconnecting the wire to the brake light switch.
jeeper54 is offline
post #6 of 8 Old 10-06-2013, 04:35 PM Thread Starter
champb00
1981 FSJ Cherokee
the haz one is top left of fuse box under dash, any idea where other one would be??
champb00 is offline
post #7 of 8 Old 10-07-2013, 08:43 PM Thread Starter
champb00
1981 FSJ Cherokee
ok got turn singal fixed. Now back on to the tail lights. Was not the brake lights. unpluged it and still lights are on on.
champb00 is offline
post #8 of 8 Old 10-22-2013, 01:05 AM
carnuck
1984 J-Series Truck
Try pulling the tail light fuse.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
