tailgate window problem - JeepForum.com
post #1 of 6 Old 03-19-2013, 09:12 PM Thread Starter
cookingguy
1979 FSJ Cherokee
So I have been having problems with the tailgate window going up and down. So I thought it might be the safty latch so I by-passed it by splicing the two brown wires together. Thought that fixed it but now it does not always want to go down using the key but can get it to go down using the switch in the cab when I wiggle the switch and get it just so. I am thinking it must have somthing to do with the switch the key operates. How can I test this? and where can I buy a new one? Thanks for any help
cookingguy is offline
post #2 of 6 Old 03-19-2013, 09:19 PM
revelc
1985 FSJ Wagoneer
Mine hasn't worked since I got it. You can try replacing the wires first. Use a test light to check voltage with key off and on.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #3 of 6 Old 03-20-2013, 04:35 AM
RockRollin
1990 FSJ Wagoneer
Not sure if you'll find a new one. Could pull the switches and clean em. I just did that on mine over the weekend, didn't know the window could move so fast
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #4 of 6 Old 03-20-2013, 07:15 AM
BJ's Off-Road
1979 FSJ Cherokee
We have this slick conversion kit for the in-tailgate switch:
http://www.bjsoffroad.com/prod-1346.htm
BJ's Off-Road is offline
post #5 of 6 Old 03-20-2013, 07:29 AM Thread Starter
cookingguy
1979 FSJ Cherokee
nice kit. But I need a new switch for in the tailgate whrere I put the key in and turn it to opperate the window
post #6 of 6 Old 03-20-2013, 07:38 AM
BJ's Off-Road
1979 FSJ Cherokee
That is what our kit is for. The switch inside the tailgate.
