Tailgate problems on a 1990 GW - JeepForum.com
post #1 of 5 Old 03-13-2013, 11:13 AM Thread Starter
Becker
1990 FSJ Wagoneer
Hi everyone, I am brand new to this forum and also brand new to Grand Wagoneers. Wondering if anyone can help me or point me in the right direction with my "new" 1990 GW.
When I purchased the vehicle, the entire tailgate window and lock assemblies had been taken out. I think I have most of the original parts but I'm not 100% sure. The regulator looks like it's missing one of it's springs/coils (I think there should be two?). Additionally, it appears that the motor for the tailgate lock may be broken. I see that BJ's sells the window lifter but I don't think that includes the regulator. I do have some concerns about some electrical elements (ie: power seats, stereo, overhead lights don't work), so I'm not even sure if this sucker would get power if I fixed the tailgate.
Does anyone have any ideas for buying replacement parts or if I can take it somewhere to get fixed? OR, if it's going to be a huge expense, does anyone have any suggestions for leaving the glass out and replacing it with something?
I bought the vehicle mostly as a junker to tow my boat. I believe the engine is sound (will be able to tell for sure once I replace the muffler and can drive it without being poisoned). I don't want to toss a ton of money at the thing right now, maybe someday if it ends up being a quality vehicle.
Since I think I can sell this for more than I bought it for, maybe the best solution is to simply buy one in better condition
Thanks!!
Becker is offline
post #2 of 5 Old 03-13-2013, 08:33 PM
super98lsc
Best option is to start with a volt meter and start checking for power then work your way back to the switches and fuse block. Check fuses first and see if any are blown or removed. The tailgate switch on the left side of instrument panel will need to have power. On the left side of tailgate there is a lever switch that prevents the window from operating if the gate isn't shut. You can bypass it if yours is broken. The regulator that moves the window is solid metal and gear teeth. Either rebuild or replace the motor if it doesn't power up. Test motor by connecting it to the battery with some test leads. Wiring diagrams help, I'll dig some up this weekend if you can't find them online
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #3 of 5 Old 03-14-2013, 04:29 AM
RockRollin
1990 FSJ Wagoneer
http://oljeep.com/gw/elec/GW_wiring-1990.html
The Saint of Wagonhood.
Good call on the safety switch. Reminds me of trying to fix my fog lights before it occured to me "TURN THE HEADLIGHTS ON"
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #4 of 5 Old 03-14-2013, 06:47 AM
super98lsc
The foglight fix is awesome man thats some funny chit
Speaking of... man you should have seen the ignorant $$$$t repair the guy did on mine... they had the ground wires taped to the bumper with METAL tape!!
post #5 of 5 Old 03-15-2013, 09:20 AM Thread Starter
Becker
1990 FSJ Wagoneer
Thanks everyone! I was able to find the wiring diagrams so that should help. Also found the pages from Tom's parts manuals for the tailgate and regulator; it looks like I'm definitely missing some parts. Now off to replace the muffler! I appreciate your help!
Becker is offline
