Suspension modification? - JeepForum.com
post #1 of 2 Old 05-23-2001, 05:58 PM Thread Starter
jgb
My 1982 Wagoneer is completely stock. I want to raise it to allow for up to 35" tires. It is my understanding that doing so will probably require changing gears and could cause driveline problems. I have no intention of off-roading, so appearance, mileage and ride are most important to me. Cost is also a consideration, but doing things the right way is most important. Any advice or information would be greatly appreciated.
jgb is offline
post #2 of 2 Old 05-29-2001, 12:15 PM
francis higgins
If ride, mileage, etc. are most important to you, consider leaving the Jeep alone. Lifting the Jeep will certainly lower your mileage (especially with 35s) and will most likely negatively affect the ride. Handling will definitely be worse. I believe you would have to lift the Wagoneer about 6 inches to fit those tires. Anything including and over 4 inches will require replacement of some steering and brake components in addition to springs. My Wagoneer is stock as well, but I would like to raise it 3 or 4 inches for off-roading. The FSJs have excellent clearance from the factory and are very capable as equipped. I will probably install 31 or 32 inch (x 10.5 inches wide) tires on the factory rims. This way they will still fit in the wheel wells without trimming fenders. Good luck on your project!
1990 Grand Wagoneer
francis higgins is offline
74 to a 76 or later suspension swap bigdawgfan Full Size Jeep Forum 1 02-08-2009 09:51 AM
Suspension on trunk stlawrence Full Size Jeep Forum 1 03-30-2007 08:39 AM
Suspension for a 68 J truck CRM Full Size Jeep Forum 1 03-19-2007 01:08 AM
Suspension/Steering help jkennedyak Full Size Jeep Forum 1 09-23-2005 03:25 PM
SUSPENSION QUESTION GREGDOG95YJ Full Size Jeep Forum 2 09-28-2001 03:26 PM
