Summit HEI coming next week - JeepForum.com
post #1 of 16 Old 05-07-2013, 07:52 AM Thread Starter
chris64
1979 FSJ Cherokee
Going to install this prior to motor swap, want to make sure it's working, one less headache after the swap.
so I need to trace the hot wire back , and add a relay for the connection?
I'm really psyched to get the new motor going!
Thank you, C
chris64 is offline
post #2 of 16 Old 05-09-2013, 08:38 AM
BJ's Off-Road
1979 FSJ Cherokee
On your ignition control module there are 2 plugs. One plug has 2 wires to it. One of those 2 wires is what you want to run the HEI, it is the thicker wire of the two.
No relay required.
BJ's Off-Road is offline
post #3 of 16 Old 05-10-2013, 07:22 AM Thread Starter
chris64
1979 FSJ Cherokee
Ryan ?
Thanks for the info!
Will continue to order from you , looks like a poly fuel tank is next..
Thank you,
C
chris64 is offline
post #4 of 16 Old 05-10-2013, 03:35 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
let us know how the install goes.
what product were you using from summit?
HEI is something I've been considering.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #5 of 16 Old 05-10-2013, 04:04 PM
revelc
1985 FSJ Wagoneer
Me too. Has anyone used D.U.I.?
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #6 of 16 Old 05-10-2013, 04:10 PM
ojr511
I installed the summit hei dist and has to be the best upgrade I have done a 1 wire upgrade I call it . I have an 89 yj 4.2 and my idle smoothed out and I can actually keep it at 400 rpm with out dying worth the money ill say that much
ojr511 is offline
post #7 of 16 Old 05-10-2013, 04:28 PM
pleontks
1976 J-Series Truck
I'm very happy with my Stealth HEI set-ups. Runs way better, and no trouble from them Even happier with my msd6a and blaster coil with the duraspark dist. If there's enough power in my battery to turn the engine even once, that msd'll fire it right up.
And they were all free.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #8 of 16 Old 05-10-2013, 05:35 PM Thread Starter
chris64
1979 FSJ Cherokee
I like the 6a boxes as well. And will probably get one at some point, and maybe a blue bottle too! Tell me more about the cam gear, the one i took off looked perfect, is it safe to reuse?
chris64 is offline
post #9 of 16 Old 05-10-2013, 06:15 PM
RockRollin
1990 FSJ Wagoneer
The cam and dizzy gears need to be a matched set. Either use the old dizzy gear that matched the cam gear, or replace with a matched set
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #10 of 16 Old 05-10-2013, 07:22 PM Thread Starter
chris64
1979 FSJ Cherokee
Cool, I'll pull the dist gear and reuse, save a couple $$
chris64 is offline
post #11 of 16 Old 05-11-2013, 09:09 PM Thread Starter
chris64
1979 FSJ Cherokee
Dist arrived today, it looks really nice.
Will drop it in shortly, and see how it goes!
chris64 is offline
post #12 of 16 Old 05-11-2013, 09:37 PM
revelc
1985 FSJ Wagoneer
Keep us posted.
revelc is offline
post #13 of 16 Old 05-12-2013, 07:34 PM Thread Starter
chris64
1979 FSJ Cherokee
Got to get some plug wires, and will drop it in on my day off!!!
I'm psyched!
chris64 is offline
post #14 of 16 Old 05-23-2013, 02:15 PM Thread Starter
chris64
1979 FSJ Cherokee
Bingo!
Super easy install, and runs way better!!!
Haven'tset timing yet, but just going down the road it feels way better.
Hardest part of install was explaining to parts store mgr that I needed hei wires...
clearance is tight with the air pump hoses, but Ima ditch that junk when new motor goes in!
C
chris64 is offline
post #15 of 16 Old 05-23-2013, 06:09 PM
olliehopnoodle
1982 FSJ Cherokee
Smart move to get it running first. Will make the engine break in easier.
You might also consider getting an extra ignition control module for it before too long. Part DR100. It's cheap (like 20 bucks) and easy to replace. But if it goes out and you are in the middle of BFE your truck isn't going to run. Cheap insurance.
It took a few years for mine to go but when they do they do.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
