-   Full Size Jeep Forum (http://www.jeepforum.com/forum/f57/)
-   -   Summit HEI coming next week (http://www.jeepforum.com/forum/f57/summit-hei-coming-next-week-1519911/)
chris64 05-07-2013 08:52 AM
Going to install this prior to motor swap, want to make sure it's working, one less headache after the swap.
so I need to trace the hot wire back , and add a relay for the connection?
I'm really psyched to get the new motor going!
Thank you, C
BJ's Off-Road 05-09-2013 09:38 AM
On your ignition control module there are 2 plugs. One plug has 2 wires to it. One of those 2 wires is what you want to run the HEI, it is the thicker wire of the two.
No relay required.
chris64 05-10-2013 08:22 AM
Ryan ?
Thanks for the info!
Will continue to order from you , looks like a poly fuel tank is next..
Thank you,
C
Marn 05-10-2013 04:35 PM
let us know how the install goes.
what product were you using from summit?
HEI is something I've been considering.
revelc 05-10-2013 05:04 PM
Me too. Has anyone used D.U.I.?
ojr511 05-10-2013 05:10 PM
I installed the summit hei dist and has to be the best upgrade I have done a 1 wire upgrade I call it . I have an 89 yj 4.2 and my idle smoothed out and I can actually keep it at 400 rpm with out dying worth the money ill say that much
pleontks 05-10-2013 05:28 PM
I'm very happy with my Stealth HEI set-ups. Runs way better, and no trouble from them Even happier with my msd6a and blaster coil with the duraspark dist. If there's enough power in my battery to turn the engine even once, that msd'll fire it right up. :)
And they were all free.
chris64 05-10-2013 06:35 PM
I like the 6a boxes as well. And will probably get one at some point, and maybe a blue bottle too! Tell me more about the cam gear, the one i took off looked perfect, is it safe to reuse?
RockRollin 05-10-2013 07:15 PM
The cam and dizzy gears need to be a matched set. Either use the old dizzy gear that matched the cam gear, or replace with a matched set
chris64 05-10-2013 08:22 PM
Cool, I'll pull the dist gear and reuse, save a couple $$
chris64 05-11-2013 10:09 PM
Dist arrived today, it looks really nice.
Will drop it in shortly, and see how it goes!
revelc 05-11-2013 10:37 PM
Keep us posted.
chris64 05-12-2013 08:34 PM
Got to get some plug wires, and will drop it in on my day off!!!
I'm psyched!
chris64 05-23-2013 03:15 PM
Bingo!
Super easy install, and runs way better!!!
Haven'tset timing yet, but just going down the road it feels way better.
Hardest part of install was explaining to parts store mgr that I needed hei wires...:confused:
clearance is tight with the air pump hoses, but Ima ditch that junk when new motor goes in!
C
olliehopnoodle 05-23-2013 07:09 PM
Smart move to get it running first. Will make the engine break in easier.
You might also consider getting an extra ignition control module for it before too long. Part DR100. It's cheap (like 20 bucks) and easy to replace. But if it goes out and you are in the middle of BFE your truck isn't going to run. Cheap insurance.
It took a few years for mine to go but when they do they do.
The time now is 07:33 AM.
